Date/Time: Sun, 16 Aug 2026 16:25:36 +0000
EUREX and ICE Support with Sierra Chart Data Feed Now Available!
View Count: 10824
| [2014-01-06 14:15:26] |
| chris12 - Posts: 53 |
So we can use the Eurex feed without using a trading service through Sierra for 66 usd (level 1&2), right ??
| [2014-01-06 17:25:53] |
| crazybears - Posts: 314 |
Hi Sierra Chart Engineering without being impolite i would ask you if you can compare your ICE data feed vs CTS T4 , mainly for TF. I'm assuming that your CME and Eurex datafeed is far superior and complete. instead if ICE ,for what i'm only interested of 1 or max 3 symbol,if will be the same than CTSt4 then i can save money for 2 year of SC subscription or add another license for your datafeed if there are huge difference i'm going to subcribe to your ICE datafeed too. |
| [2014-01-07 01:20:12] |
Yes.without being impolite i would ask you if you can compare your ICE data feed vs CTS T4 , mainly for TF.
Here is a image of a chart using New York time stamping for the TF:http://www.sierrachart.com/image.php?l=1389057679446.png The Sierra Chart EUREX data feed will be the same as the CTS T4 EUREX data feed because the T4 data feed also provides tick by tick data. As of this writing though there is a slight problem with the bid/ask data timing with the Sierra Chart EUREX data feed which causes some amount of inaccuracy with bid volume and ask volume calculations. Whether there is an advantage with ICE, we do not know. We would think they would be minimal difference. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-26 21:04:27
| [2014-01-26 11:11:24] |
| User40117 - Posts: 56 |
@crossiman: would you like so share your experiences with this data feed, SC and IB ? i'm thinking of switching myself to this setup. ty and regards |
| [2014-01-26 15:38:53] |
| User94740 - Posts: 333 |
Hi SC, if I am subscribed to this new data feed service, is FOREX also running parallel with the service?
| [2014-01-26 21:02:30] |
If you also want to use the Sierra Chart Real-time and Historical Forex Data Service, you will then need to install another copy of Sierra Chart: https://www.sierrachart.com/index.php?l=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-27 16:25:49
| [2014-01-27 10:33:27] |
Hi SC, just to let you know, but my Forex data is also being updated at the same time with SC Real Time.
| [2014-01-27 16:26:45] |
Maybe we are misunderstanding what you want. Are you referring to Forex futures? What do you have the Global Settings >> Data/Trade Service Settings >> Service set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-01-27 17:14:44] |
just normal currency pairs settings are for IB |
| [2014-01-27 17:50:51] |
If you are referring to spot Forex symbols when using Interactive Brokers, this data will come from Interactive Brokers.
| [2014-01-28 07:50:23] |
| CT - Posts: 4 |
hi, subscribed to this feed but. I selected SC Exchange Data. I don't have the [M] after the symbol intraday chart is not updated, MarketDepth is empty... session time is set 24h but i don't see pre and aftermarket... I'm switching broker not using any in SC yet. I only need FDAX btw |
| [2014-01-28 08:14:06] |
See step 6 and 7 here: https://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions You need to enable the EUREX exchange. Please be aware that you will be charged $31.50 in full for the EUREX for the month of January. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-01-28 08:23:31] |
| CT - Posts: 4 |
okay. "Eurex feed for professional users" What's the difference ? I was earlier informed that fee's for individuals or business are equal. |
| [2014-01-28 08:34:42] |
This would be if you are a member of the EUREX exchange as we understand. There is absolutely no difference with the data feed itself.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-28 08:34:57
| [2014-01-29 20:20:05] |
Any feedback would be appreciated from users of the eurex feed...
| [2014-01-29 21:54:26] |
The Sierra Chart EUREX data feed is definitely very good. There previously were questions about the bid volume and Ask volume and we have resolved that and provided a complete technical discussion. Refer to these images comparing the Sierra Chart EUREX data feed to IQ Feed using Cumulative Delta Bars-Volume study. http://www.sierrachart.com/image.php?l=1391032429393.png (IQ Feed) http://www.sierrachart.com/image.php?l=1391032445308.png (Sierra Chart EUREX data feed) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-29 21:55:34
| [2014-01-29 22:24:27] |
Another thing we want to point out with IQ Feed, the bid volume and ask volume is not "right or "correct". It is not possible to do with how the EUREX data feed works. The Sierra Chart EUREX data feed provides a good result in this regard. And we contend that it is a better result because it uses a more consistent and stable calculation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-01-31 21:34:38] |
hi SC i suscribed to the EUREX feed, i'm connected but don't receive any data. There's no "M" indicator on the top line… could you help me |
| [2014-02-01 03:16:41] |
It appears as though you are not using the correct symbol. Select File >> Find Symbol and choose the particular futures contract that you want to chart. If you need help, let us know what futures markets you want to chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-02-03 17:37:09] |
| user14348 - Posts: 5 |
hi, i try to activate the SC market data feed, and i received this message could you help me |
| [2014-02-03 18:45:38] |
The problem is your Market Data Feed Agreement has not been approved yet. We will check on it. We checked on it and it was not approved and we have given the reasons why. Please see the email message about this and reply to us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-03 18:49:22
| [2014-02-03 18:52:11] |
Hi reads post #11 #17 #18 , can i activate only Eurex datafeed and use it without a broker and lately , next month , subscribe to CME putting my broker ? i would use Eurex on a copy of SC and CME on another copy . |
| [2014-02-03 20:40:47] |
The Sierra Chart EUREX data feed can be used independent of a broker/trading service. The CME data feed cannot be. You can install multiple copies of Sierra Chart on your system using a different Data or Trading service with each.
| [2014-02-03 22:13:48] |
Hi I'm trying to add Eurex data feed but returns error messages : Failed to extend feature expiration date. Market Data Agreement not approved. Failed to activate the Market Data Feed. also i have indicate my broker , could i use eurex feed without it ? |
| [2014-02-03 22:54:27] |
We have approved your Market Data Feed Agreement. You will be able to activate the data feed now. After you do that, restart Sierra Chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-03 22:54:46
| [2014-02-03 23:01:26] |
i made some mistakes :( , i want activate only Eurex but i think i activated CME could you help me
