Date/Time: Sun, 04 Oct 2026 05:27:28 +0000
[Programming Help] - Documentation lacking
View Count: 925
[2020-01-13 11:59:03]
User255315 - Posts: 133
Hi SC,
Can we get slightly illustrative documentation/examples on functions like sc.OpenFile, sc.GetFileErrorMessageCode, sc.ReadFile. There are no instructions on how to declare the enumerations that these functions use, nor are there any source codes showing any file handling example. It would be really helpful if we could get an ACSIL example for the aforementioned functions.
Thanks in Advance!
[2020-01-14 04:54:22]
Hi SC,
I played around with the sc.OpenFile and sc.ReadFile functions however i get the following error message: FileHandler needs to be recompiled for this version of Sierra Chart. | 2020-01-14 04:50:57.281 *
FileHandler needs to be recompiled for this version of Sierra Chart. | 2020-01-14 04:50:57.789 * (FileHandler is the name of the file)
This error message is persisting even after I have used the int types for function parameters as mentioned in your Update Notes for version 2017.
Could you please look into what is wrong here? Or if possible, update an example code for the new sc.OpenFile function?
