Date/Time: Sun, 04 Oct 2026 04:20:00 +0000
Stock Index Premiums location with Sierra Exch. data feed.
View Count: 802
| [2020-01-08 22:29:41] |
| SierraFan - Posts: 92 |
I can pull up the stock index premiums ex.ESH20-INX if data/trade services set to all services. Once I change to SC Futures Order Routing/Data nothing shows up in the premiums section. Can you/anyone advice? Thanks
| [2020-01-08 22:53:25] |
We will look into this now.
| [2020-01-09 00:47:13] |
Wow Sierra!!! That was quick!!! Thank You Sierra its showing up and working!
| [2020-01-09 17:04:51] |
Sierra, ESH20-INX is appx 20mins behind/delayed. Do I need to activate something to get live data? If so can you direct me where? Thank You
