Date/Time: Sun, 04 Oct 2026 04:20:03 +0000
ZigZag missing labels on some zigszags
View Count: 1044
| [2020-01-05 14:23:57] |
| ycomp - Posts: 334 |
why does no data show above the top zig/zag in the chart? this is the zizag study with calculation type 2 |
| [2020-01-06 20:10:24] |
There should not be a problem with this. We have never known there to be any issue like this. Provide that chart by following these instructions: Support Board Posting Information: Attaching a File (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-01-07 13:53:03] |
screenshot is gbpusd sc feed that comes with sc i think using fxcm data, showing an example in this chartbook
| [2020-01-09 15:02:52] |
| John - SC Support - Posts: 48095 |
Can you please attach your Sierra3.cfg file to this thread. It is located in your top-level Sierra Chart directory. Typically this would be C:\SierraChart, but may be different if you installed to a different directory.
| [2020-01-09 16:01:16] |
The reason there are no labels on some of the reversal points is that those are the start of a new trading day, and you have the option for Reset Zig Zag at Start of Trading Day set to Yes. Since that is an artificial starting point, there is no Zig Zag data to display at those points. This is explained here: Zig Zag: Reset Zig Zag at Start of Trading Day For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
