Date/Time: Thu, 17 Sep 2026 04:08:47 +0000
[User Discussion] - How do I turn off daily P/L in trade window?
View Count: 1571
| [2013-04-12 16:15:54] |
| Zonescalper - Posts: 6 |
Dear support, How do I turn off the daily P/L in the trade window without turning off the current P/L of the trade? When I use "Do not display" at the Positions Profit/Loss section I also turn off the current P/L. I don't want to do that. Please advice. Kind regards, Zonescalper |
| [2015-03-11 02:43:48] |
| Acro - Posts: 459 |
Does anyone know if this has been answered or resolved ? I find it distracting to the current trade to know how many ticks up or down I am for the whole day. Being able to turn this off completely would be a great help |
| [2015-03-11 03:24:28] |
| Acro - Posts: 459 |
Further to my last comment, I think there is some form of bug in the Display Daily P/L in the Trade DOM if it is switched off in the Chart Trade Options. When it's switched off and you take a test trade and it loses one tick (eg buy and sell at market immediately) then that -1t is immediately displayed in the Daily P/L in the Trade DOM despite it being switched off. I would think it should stay at zero if it switched off ! However, for every subsequent trade you take the Daily P/L stays at -1 regardless of whether you won or lost any ticks It seems very strange |
| [2015-03-13 08:08:43] |
Refer to the documentation here: Help With Daily Profit/Loss Value It does not work this way. There is never a chance it ever would work this way: I would think it should stay at zero if it switched off !
