Date/Time: Sun, 01 Nov 2026 15:37:59 +0000
Volume By Price
View Count: 2397
| [2013-12-30 08:34:06] |
| User57821 - Posts: 18 |
Hello, I'm using SCH Real-Time data feed. In message log is still running: ''Chart:NQH4-CME[M] 2min #5/Study: Volume By Price/Exception occurred while calling study function.''. It is when setting Volume Graph Period Type: From Session Start to End, when changing to: Visible Bars then is it o.k. Thank you for your help. Martin |
| [2013-12-30 10:37:00] |
We cannot duplicate the problem and we have never heard of this before. Are you running any custom studies on your charts? Refer to help topic 17 for help with this: http://www.sierrachart.com/index.php?l=doc/helpdetails17.html If not, we will need to get a Chartbook containing 1 simple chart that demonstrates the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-01-06 16:42:05] |
Hello, In message log is still running: ''Chart:NQH4-CME[M] 2min #5/Study: Volume By Price/Exception occurred while calling study function.''. It is the same with ES, but only when setting Volume Graph Period Type: From Session Start to End, when changing to: Visible Bars then is it o.k. Any custom studies on my charts. http://www.sierrachart.com/image.php?l=1389026383990.png http://www.sierrachart.com/image.php?l=1389026430663.png Software version: 1070 | 2014-01-06 14:03:08 Usage end date: 2014-04-01 | 2014-01-06 14:03:08 Enabled for: Sierra Chart Historical Data Service. | 2014-01-06 14:03:08 Enabled for: Sierra Chart Real-Time Market Data Feed. | 2014-01-06 14:03:08 Enabled for: CME Exchange with trading fee waiver. | 2014-01-06 14:03:08 Received 1 data feed usernames. | 2014-01-06 14:03:08 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-01-06 14:03:08 Active service: Interactive Brokers | 2014-01-06 14:03:08 Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2014-01-06 14:03:08 2014-01-06 14:03:08 Local computer clock time | 2014-01-06 14:03:08 2014-01-06 13:03:08 GMT time | 2014-01-06 14:03:08 2014-01-06 14:03:08 Time zone adjusted time | 2014-01-06 14:03:08 Time difference to server time: 0 seconds. | 2014-01-06 14:03:08 Program path: C:\SierraChart_IB\ | 2014-01-06 14:03:08 Data Files path: C:\SierraChart_IB\Data\ | 2014-01-06 14:03:08 OS Version Number: 5.1 | 2014-01-06 14:03:08 Checking for new symbol settings for ib | 2014-01-06 14:03:08 Requesting symbol settings for ib. Overwrite = on. | 2014-01-06 14:03:08 Request for symbol settings completed. | 2014-01-06 14:03:08 Processed received symbol settings | 2014-01-06 14:03:08 Checking for large (over 300 MB) intraday data files to move data out of. Please wait.... | 2014-01-06 14:03:10 Completed checking of 12 Intraday data files (*.scid). | 2014-01-06 14:03:15 Date rule based rollover from ESM11 to next contract occurs at 2011-06-09 | 2014-01-06 14:03:29 Date rule based rollover from ESU11 to next contract occurs at 2011-09-08 | 2014-01-06 14:03:29 Date rule based rollover from ESZ11 to next contract occurs at 2011-12-08 | 2014-01-06 14:03:29 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08 | 2014-01-06 14:03:29 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07 | 2014-01-06 14:03:29 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13 | 2014-01-06 14:03:29 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13 | 2014-01-06 14:03:29 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07 | 2014-01-06 14:03:29 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13 | 2014-01-06 14:03:29 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12 | 2014-01-06 14:03:29 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12 | 2014-01-06 14:03:29 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13 | 2014-01-06 14:03:29 Checking Daily data file for symbol ESM11 for the date range from 2011-03-10 to 2011-06-04 | 2014-01-06 14:03:29 Checking Daily data file for symbol ESU11 for the date range from 2011-06-09 to 2011-09-03 | 2014-01-06 14:03:29 Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-03 | 2014-01-06 14:03:30 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-03 | 2014-01-06 14:03:30 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-02 | 2014-01-06 14:03:30 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-08 | 2014-01-06 14:03:30 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-08 | 2014-01-06 14:03:31 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-02 | 2014-01-06 14:03:31 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-08 | 2014-01-06 14:03:31 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-07 | 2014-01-06 14:03:31 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-07 | 2014-01-06 14:03:31 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to | 2014-01-06 14:03:31 Symbols used for ESH14 continuous contract chart: | 2014-01-06 14:03:31 ESM11 | 2014-01-06 14:03:31 ESU11 | 2014-01-06 14:03:31 ESZ11 | 2014-01-06 14:03:31 ESH12 | 2014-01-06 14:03:31 ESM12 | 2014-01-06 14:03:31 ESU12 | 2014-01-06 14:03:31 ESZ12 | 2014-01-06 14:03:31 ESH13 | 2014-01-06 14:03:31 ESM13 | 2014-01-06 14:03:31 ESU13 | 2014-01-06 14:03:31 ESZ13 | 2014-01-06 14:03:31 ESH14 | 2014-01-06 14:03:31 Volume based rollover from ESM11 to ESU11 occurs at 2011-06-10 | 2014-01-06 14:03:31 Volume based rollover from ESU11 to ESZ11 occurs at 2011-09-09 | 2014-01-06 14:03:32 Volume based rollover from ESZ11 to ESH12 occurs at 2011-12-09 | 2014-01-06 14:03:32 Volume based rollover from ESH12 to ESM12 occurs at 2012-03-09 | 2014-01-06 14:03:32 Volume based rollover from ESM12 to ESU12 occurs at 2012-06-08 | 2014-01-06 14:03:32 Volume based rollover from ESU12 to ESZ12 occurs at 2012-09-14 | 2014-01-06 14:03:32 Volume based rollover from ESZ12 to ESH13 occurs at 2012-12-14 | 2014-01-06 14:03:32 Volume based rollover from ESH13 to ESM13 occurs at 2013-03-08 | 2014-01-06 14:03:32 Volume based rollover from ESM13 to ESU13 occurs at 2013-06-14 | 2014-01-06 14:03:32 Volume based rollover from ESU13 to ESZ13 occurs at 2013-09-13 | 2014-01-06 14:03:32 Volume based rollover from ESZ13 to ESH14 occurs at 2013-12-13 | 2014-01-06 14:03:32 Date rule based rollover from EUR-201309-GLOBEX to next contract occurs at 2013-09-16 | 2014-01-06 14:03:33 Date rule based rollover from EUR-201312-GLOBEX to next contract occurs at 2013-12-16 | 2014-01-06 14:03:33 Date rule based rollover from EUR-201403-GLOBEX to next contract occurs at 2014-03-17 | 2014-01-06 14:03:33 Checking Intraday data file for symbol EUR-201309-GLOBEX for the date range from 2013-06-17 to 2013-09-16 | 2014-01-06 14:03:33 Checking Intraday data file for symbol EUR-201312-GLOBEX for the date range from 2013-09-16 to 2013-12-16 | 2014-01-06 14:03:33 Checking Intraday data file for symbol EUR-201403-GLOBEX for the date range from 2013-12-16 to | 2014-01-06 14:03:34 Symbols used for EUR-201403-GLOBEX continuous contract chart: | 2014-01-06 14:03:34 EUR-201309-GLOBEX | 2014-01-06 14:03:34 EUR-201312-GLOBEX | 2014-01-06 14:03:34 EUR-201403-GLOBEX | 2014-01-06 14:03:34 Date rule based rollover from E6M11 to next contract occurs at 2011-06-13 | 2014-01-06 14:03:35 Date rule based rollover from E6U11 to next contract occurs at 2011-09-19 | 2014-01-06 14:03:35 Date rule based rollover from E6Z11 to next contract occurs at 2011-12-19 | 2014-01-06 14:03:35 Date rule based rollover from E6H12 to next contract occurs at 2012-03-19 | 2014-01-06 14:03:35 Date rule based rollover from E6M12 to next contract occurs at 2012-06-18 | 2014-01-06 14:03:35 Date rule based rollover from E6U12 to next contract occurs at 2012-09-17 | 2014-01-06 14:03:35 Date rule based rollover from E6Z12 to next contract occurs at 2012-12-17 | 2014-01-06 14:03:35 Date rule based rollover from E6H13 to next contract occurs at 2013-03-18 | 2014-01-06 14:03:35 Date rule based rollover from E6M13 to next contract occurs at 2013-06-17 | 2014-01-06 14:03:35 Date rule based rollover from E6U13 to next contract occurs at 2013-09-16 | 2014-01-06 14:03:35 Date rule based rollover from E6Z13 to next contract occurs at 2013-12-16 | 2014-01-06 14:03:35 Date rule based rollover from E6H14 to next contract occurs at 2014-03-17 | 2014-01-06 14:03:35 Checking Daily data file for symbol E6M11 for the date range from 2011-03-14 to 2011-06-08 | 2014-01-06 14:03:35 Checking Daily data file for symbol E6U11 for the date range from 2011-06-13 to 2011-09-14 | 2014-01-06 14:03:35 Checking Daily data file for symbol E6Z11 for the date range from 2011-09-19 to 2011-12-14 | 2014-01-06 14:03:35 Checking Daily data file for symbol E6H12 for the date range from 2011-12-19 to 2012-03-14 | 2014-01-06 14:03:35 Checking Daily data file for symbol E6M12 for the date range from 2012-03-19 to 2012-06-13 | 2014-01-06 14:03:35 Checking Daily data file for symbol E6U12 for the date range from 2012-06-18 to 2012-09-12 | 2014-01-06 14:03:36 Checking Daily data file for symbol E6Z12 for the date range from 2012-09-17 to 2012-12-12 | 2014-01-06 14:03:36 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-13 | 2014-01-06 14:03:36 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-12 | 2014-01-06 14:03:36 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-11 | 2014-01-06 14:03:36 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-11 | 2014-01-06 14:03:36 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to | 2014-01-06 14:03:36 Symbols used for E6H14 continuous contract chart: | 2014-01-06 14:03:36 E6M11 | 2014-01-06 14:03:36 E6U11 | 2014-01-06 14:03:36 E6Z11 | 2014-01-06 14:03:36 E6H12 | 2014-01-06 14:03:36 E6M12 | 2014-01-06 14:03:36 E6U12 | 2014-01-06 14:03:36 E6Z12 | 2014-01-06 14:03:36 E6H13 | 2014-01-06 14:03:36 E6M13 | 2014-01-06 14:03:36 E6U13 | 2014-01-06 14:03:36 E6Z13 | 2014-01-06 14:03:36 E6H14 | 2014-01-06 14:03:36 Volume based rollover from E6M11 to E6U11 occurs at 2011-06-10 | 2014-01-06 14:03:36 Volume based rollover from E6U11 to E6Z11 occurs at 2011-09-16 | 2014-01-06 14:03:36 Volume based rollover from E6Z11 to E6H12 occurs at 2011-12-16 | 2014-01-06 14:03:36 Volume based rollover from E6H12 to E6M12 occurs at 2012-03-16 | 2014-01-06 14:03:36 Volume based rollover from E6M12 to E6U12 occurs at 2012-06-15 | 2014-01-06 14:03:36 Volume based rollover from E6U12 to E6Z12 occurs at 2012-09-14 | 2014-01-06 14:03:36 Volume based rollover from E6Z12 to E6H13 occurs at 2012-12-14 | 2014-01-06 14:03:36 Volume based rollover from E6H13 to E6M13 occurs at 2013-03-15 | 2014-01-06 14:03:36 Volume based rollover from E6M13 to E6U13 occurs at 2013-06-14 | 2014-01-06 14:03:36 Volume based rollover from E6U13 to E6Z13 occurs at 2013-09-13 | 2014-01-06 14:03:36 Volume based rollover from E6Z13 to E6H14 occurs at 2013-12-13 | 2014-01-06 14:03:37 No SC real-time data feed mapping found for symbol: EUR.USD-CASH-IDEALPRO | 2014-01-06 14:03:37 Date rule based rollover from E6U08 to next contract occurs at 2008-09-15 | 2014-01-06 14:03:37 Date rule based rollover from E6Z08 to next contract occurs at 2008-12-15 | 2014-01-06 14:03:37 Date rule based rollover from E6H09 to next contract occurs at 2009-03-16 | 2014-01-06 14:03:37 Date rule based rollover from E6M09 to next contract occurs at 2009-06-15 | 2014-01-06 14:03:37 Date rule based rollover from E6U09 to next contract occurs at 2009-09-14 | 2014-01-06 14:03:37 Date rule based rollover from E6Z09 to next contract occurs at 2009-12-14 | 2014-01-06 14:03:37 Date rule based rollover from E6H10 to next contract occurs at 2010-03-15 | 2014-01-06 14:03:37 Date rule based rollover from E6M10 to next contract occurs at 2010-06-14 | 2014-01-06 14:03:37 Date rule based rollover from E6U10 to next contract occurs at 2010-09-13 | 2014-01-06 14:03:37 Date rule based rollover from E6Z10 to next contract occurs at 2010-12-13 | 2014-01-06 14:03:37 Date rule based rollover from E6H11 to next contract occurs at 2011-03-14 | 2014-01-06 14:03:37 Date rule based rollover from E6M11 to next contract occurs at 2011-06-13 | 2014-01-06 14:03:37 Date rule based rollover from E6U11 to next contract occurs at 2011-09-19 | 2014-01-06 14:03:37 Date rule based rollover from E6Z11 to next contract occurs at 2011-12-19 | 2014-01-06 14:03:37 Date rule based rollover from E6H12 to next contract occurs at 2012-03-19 | 2014-01-06 14:03:37 Date rule based rollover from E6M12 to next contract occurs at 2012-06-18 | 2014-01-06 14:03:37 Date rule based rollover from E6U12 to next contract occurs at 2012-09-17 | 2014-01-06 14:03:37 Date rule based rollover from E6Z12 to next contract occurs at 2012-12-17 | 2014-01-06 14:03:37 Date rule based rollover from E6H13 to next contract occurs at 2013-03-18 | 2014-01-06 14:03:37 Date rule based rollover from E6M13 to next contract occurs at 2013-06-17 | 2014-01-06 14:03:37 Date rule based rollover from E6U13 to next contract occurs at 2013-09-16 | 2014-01-06 14:03:37 Date rule based rollover from E6Z13 to next contract occurs at 2013-12-16 | 2014-01-06 14:03:37 Date rule based rollover from E6H14 to next contract occurs at 2014-03-17 | 2014-01-06 14:03:37 Checking Daily data file for symbol E6U08 for the date range from 2008-06-16 to 2008-09-10 | 2014-01-06 14:03:37 Checking Daily data file for symbol E6Z08 for the date range from 2008-09-15 to 2008-12-10 | 2014-01-06 14:03:37 Checking Daily data file for symbol E6H09 for the date range from 2008-12-15 to 2009-03-11 | 2014-01-06 14:03:37 Checking Daily data file for symbol E6M09 for the date range from 2009-03-16 to 2009-06-10 | 2014-01-06 14:03:38 Checking Daily data file for symbol E6U09 for the date range from 2009-06-15 to 2009-09-09 | 2014-01-06 14:03:38 Checking Daily data file for symbol E6Z09 for the date range from 2009-09-14 to 2009-12-09 | 2014-01-06 14:03:38 Checking Daily data file for symbol E6H10 for the date range from 2009-12-14 to 2010-03-10 | 2014-01-06 14:03:38 Checking Daily data file for symbol E6M10 for the date range from 2010-03-15 to 2010-06-09 | 2014-01-06 14:03:38 Checking Daily data file for symbol E6U10 for the date range from 2010-06-14 to 2010-09-08 | 2014-01-06 14:03:38 Checking Daily data file for symbol E6Z10 for the date range from 2010-09-13 to 2010-12-08 | 2014-01-06 14:03:38 Checking Daily data file for symbol E6H11 for the date range from 2010-12-13 to 2011-03-09 | 2014-01-06 14:03:38 Checking Daily data file for symbol E6M11 for the date range from 2011-03-14 to 2011-06-08 | 2014-01-06 14:03:39 Checking Daily data file for symbol E6U11 for the date range from 2011-06-13 to 2011-09-14 | 2014-01-06 14:03:39 Checking Daily data file for symbol E6Z11 for the date range from 2011-09-19 to 2011-12-14 | 2014-01-06 14:03:39 Checking Daily data file for symbol E6H12 for the date range from 2011-12-19 to 2012-03-14 | 2014-01-06 14:03:39 Checking Daily data file for symbol E6M12 for the date range from 2012-03-19 to 2012-06-13 | 2014-01-06 14:03:39 Checking Daily data file for symbol E6U12 for the date range from 2012-06-18 to 2012-09-12 | 2014-01-06 14:03:39 Checking Daily data file for symbol E6Z12 for the date range from 2012-09-17 to 2012-12-12 | 2014-01-06 14:03:39 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-13 | 2014-01-06 14:03:39 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-12 | 2014-01-06 14:03:39 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-11 | 2014-01-06 14:03:39 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-11 | 2014-01-06 14:03:39 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to | 2014-01-06 14:03:39 Symbols used for E6H14 continuous contract chart: | 2014-01-06 14:03:39 E6U08 | 2014-01-06 14:03:39 E6Z08 | 2014-01-06 14:03:39 E6H09 | 2014-01-06 14:03:39 E6M09 | 2014-01-06 14:03:39 E6U09 | 2014-01-06 14:03:39 E6Z09 | 2014-01-06 14:03:39 E6H10 | 2014-01-06 14:03:39 E6M10 | 2014-01-06 14:03:39 E6U10 | 2014-01-06 14:03:39 E6Z10 | 2014-01-06 14:03:39 E6H11 | 2014-01-06 14:03:39 E6M11 | 2014-01-06 14:03:39 E6U11 | 2014-01-06 14:03:39 E6Z11 | 2014-01-06 14:03:39 E6H12 | 2014-01-06 14:03:39 E6M12 | 2014-01-06 14:03:39 E6U12 | 2014-01-06 14:03:39 E6Z12 | 2014-01-06 14:03:39 E6H13 | 2014-01-06 14:03:39 E6M13 | 2014-01-06 14:03:39 E6U13 | 2014-01-06 14:03:39 E6Z13 | 2014-01-06 14:03:39 E6H14 | 2014-01-06 14:03:39 No SC real-time data feed mapping found for symbol: EUR.USD-CASH-IDEALPRO | 2014-01-06 14:03:40 Mapping EUR-201403-GLOBEX to 6EH4. Service code: cme | 2014-01-06 14:03:41 HD Request # 2 - Downloading Historical Daily chart data for E6H14. Starting date: 2014-01-02. Service: ib | 2014-01-06 14:03:41 HD Request # 2 - Using user Barchart Historical data account. | 2014-01-06 14:03:41 HD Request # 2 - Requesting historical Daily data for E6H14 starting at 2014-01-01 | 2014-01-06 14:03:41 No SC real-time data feed mapping found for symbol: EUR.USD-CASH-IDEALPRO | 2014-01-06 14:03:43 HD Request # 2 - Receiving historical Daily data for E6H14 starting at 2014-01-02 | 2014-01-06 14:03:43 Writing historical Daily data for E6H14 to the file E6H14.dly | 2014-01-06 14:03:43 HD Request # 2 - Received 3 records from 2014-01-02 00:00:00 to 2014-01-06 00:00:00 (5.0 days) and wrote 3 records for E6H14 | 2014-01-06 14:03:43 HD Request # 2 - Daily download COMPLETE for E6H14 | 2014-01-06 14:03:43 Date rule based rollover from E6M11 to next contract occurs at 2011-06-13 | 2014-01-06 14:03:43 Date rule based rollover from E6U11 to next contract occurs at 2011-09-19 | 2014-01-06 14:03:43 Date rule based rollover from E6Z11 to next contract occurs at 2011-12-19 | 2014-01-06 14:03:43 Date rule based rollover from E6H12 to next contract occurs at 2012-03-19 | 2014-01-06 14:03:43 Date rule based rollover from E6M12 to next contract occurs at 2012-06-18 | 2014-01-06 14:03:43 Date rule based rollover from E6U12 to next contract occurs at 2012-09-17 | 2014-01-06 14:03:43 Date rule based rollover from E6Z12 to next contract occurs at 2012-12-17 | 2014-01-06 14:03:43 Date rule based rollover from E6H13 to next contract occurs at 2013-03-18 | 2014-01-06 14:03:43 Date rule based rollover from E6M13 to next contract occurs at 2013-06-17 | 2014-01-06 14:03:43 Date rule based rollover from E6U13 to next contract occurs at 2013-09-16 | 2014-01-06 14:03:43 Date rule based rollover from E6Z13 to next contract occurs at 2013-12-16 | 2014-01-06 14:03:43 Date rule based rollover from E6H14 to next contract occurs at 2014-03-17 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6M11 for the date range from 2011-03-14 to 2011-06-08 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6U11 for the date range from 2011-06-13 to 2011-09-14 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6Z11 for the date range from 2011-09-19 to 2011-12-14 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6H12 for the date range from 2011-12-19 to 2012-03-14 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6M12 for the date range from 2012-03-19 to 2012-06-13 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6U12 for the date range from 2012-06-18 to 2012-09-12 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6Z12 for the date range from 2012-09-17 to 2012-12-12 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-13 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-12 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-11 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-11 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to | 2014-01-06 14:03:43 Symbols used for E6H14 continuous contract chart: | 2014-01-06 14:03:43 E6M11 | 2014-01-06 14:03:43 E6U11 | 2014-01-06 14:03:43 E6Z11 | 2014-01-06 14:03:43 E6H12 | 2014-01-06 14:03:43 E6M12 | 2014-01-06 14:03:43 E6U12 | 2014-01-06 14:03:43 E6Z12 | 2014-01-06 14:03:43 E6H13 | 2014-01-06 14:03:43 E6M13 | 2014-01-06 14:03:43 E6U13 | 2014-01-06 14:03:43 E6Z13 | 2014-01-06 14:03:43 E6H14 | 2014-01-06 14:03:43 Volume based rollover from E6M11 to E6U11 occurs at 2011-06-10 | 2014-01-06 14:03:43 Volume based rollover from E6U11 to E6Z11 occurs at 2011-09-16 | 2014-01-06 14:03:43 Volume based rollover from E6Z11 to E6H12 occurs at 2011-12-16 | 2014-01-06 14:03:43 Volume based rollover from E6H12 to E6M12 occurs at 2012-03-16 | 2014-01-06 14:03:43 Volume based rollover from E6M12 to E6U12 occurs at 2012-06-15 | 2014-01-06 14:03:43 Volume based rollover from E6U12 to E6Z12 occurs at 2012-09-14 | 2014-01-06 14:03:43 Volume based rollover from E6Z12 to E6H13 occurs at 2012-12-14 | 2014-01-06 14:03:43 Volume based rollover from E6H13 to E6M13 occurs at 2013-03-15 | 2014-01-06 14:03:43 Volume based rollover from E6M13 to E6U13 occurs at 2013-06-14 | 2014-01-06 14:03:43 Volume based rollover from E6U13 to E6Z13 occurs at 2013-09-13 | 2014-01-06 14:03:43 Volume based rollover from E6Z13 to E6H14 occurs at 2013-12-13 | 2014-01-06 14:03:43 Date rule based rollover from E6U08 to next contract occurs at 2008-09-15 | 2014-01-06 14:03:43 Date rule based rollover from E6Z08 to next contract occurs at 2008-12-15 | 2014-01-06 14:03:43 Date rule based rollover from E6H09 to next contract occurs at 2009-03-16 | 2014-01-06 14:03:43 Date rule based rollover from E6M09 to next contract occurs at 2009-06-15 | 2014-01-06 14:03:43 Date rule based rollover from E6U09 to next contract occurs at 2009-09-14 | 2014-01-06 14:03:43 Date rule based rollover from E6Z09 to next contract occurs at 2009-12-14 | 2014-01-06 14:03:43 Date rule based rollover from E6H10 to next contract occurs at 2010-03-15 | 2014-01-06 14:03:43 Date rule based rollover from E6M10 to next contract occurs at 2010-06-14 | 2014-01-06 14:03:43 Date rule based rollover from E6U10 to next contract occurs at 2010-09-13 | 2014-01-06 14:03:43 Date rule based rollover from E6Z10 to next contract occurs at 2010-12-13 | 2014-01-06 14:03:43 Date rule based rollover from E6H11 to next contract occurs at 2011-03-14 | 2014-01-06 14:03:43 Date rule based rollover from E6M11 to next contract occurs at 2011-06-13 | 2014-01-06 14:03:43 Date rule based rollover from E6U11 to next contract occurs at 2011-09-19 | 2014-01-06 14:03:43 Date rule based rollover from E6Z11 to next contract occurs at 2011-12-19 | 2014-01-06 14:03:43 Date rule based rollover from E6H12 to next contract occurs at 2012-03-19 | 2014-01-06 14:03:43 Date rule based rollover from E6M12 to next contract occurs at 2012-06-18 | 2014-01-06 14:03:43 Date rule based rollover from E6U12 to next contract occurs at 2012-09-17 | 2014-01-06 14:03:43 Date rule based rollover from E6Z12 to next contract occurs at 2012-12-17 | 2014-01-06 14:03:43 Date rule based rollover from E6H13 to next contract occurs at 2013-03-18 | 2014-01-06 14:03:43 Date rule based rollover from E6M13 to next contract occurs at 2013-06-17 | 2014-01-06 14:03:43 Date rule based rollover from E6U13 to next contract occurs at 2013-09-16 | 2014-01-06 14:03:43 Date rule based rollover from E6Z13 to next contract occurs at 2013-12-16 | 2014-01-06 14:03:43 Date rule based rollover from E6H14 to next contract occurs at 2014-03-17 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6U08 for the date range from 2008-06-16 to 2008-09-10 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6Z08 for the date range from 2008-09-15 to 2008-12-10 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6H09 for the date range from 2008-12-15 to 2009-03-11 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6M09 for the date range from 2009-03-16 to 2009-06-10 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6U09 for the date range from 2009-06-15 to 2009-09-09 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6Z09 for the date range from 2009-09-14 to 2009-12-09 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6H10 for the date range from 2009-12-14 to 2010-03-10 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6M10 for the date range from 2010-03-15 to 2010-06-09 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6U10 for the date range from 2010-06-14 to 2010-09-08 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6Z10 for the date range from 2010-09-13 to 2010-12-08 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6H11 for the date range from 2010-12-13 to 2011-03-09 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6M11 for the date range from 2011-03-14 to 2011-06-08 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6U11 for the date range from 2011-06-13 to 2011-09-14 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6Z11 for the date range from 2011-09-19 to 2011-12-14 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6H12 for the date range from 2011-12-19 to 2012-03-14 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6M12 for the date range from 2012-03-19 to 2012-06-13 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6U12 for the date range from 2012-06-18 to 2012-09-12 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6Z12 for the date range from 2012-09-17 to 2012-12-12 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-13 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-12 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-11 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-11 | 2014-01-06 14:03:43 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to | 2014-01-06 14:03:43 Symbols used for E6H14 continuous contract chart: | 2014-01-06 14:03:43 E6U08 | 2014-01-06 14:03:43 E6Z08 | 2014-01-06 14:03:43 E6H09 | 2014-01-06 14:03:43 E6M09 | 2014-01-06 14:03:43 E6U09 | 2014-01-06 14:03:43 E6Z09 | 2014-01-06 14:03:43 E6H10 | 2014-01-06 14:03:43 E6M10 | 2014-01-06 14:03:43 E6U10 | 2014-01-06 14:03:43 E6Z10 | 2014-01-06 14:03:43 E6H11 | 2014-01-06 14:03:43 E6M11 | 2014-01-06 14:03:43 E6U11 | 2014-01-06 14:03:43 E6Z11 | 2014-01-06 14:03:43 E6H12 | 2014-01-06 14:03:43 E6M12 | 2014-01-06 14:03:43 E6U12 | 2014-01-06 14:03:43 E6Z12 | 2014-01-06 14:03:43 E6H13 | 2014-01-06 14:03:43 E6M13 | 2014-01-06 14:03:43 E6U13 | 2014-01-06 14:03:43 E6Z13 | 2014-01-06 14:03:43 E6H14 | 2014-01-06 14:03:43 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-01-06 14:03:44 The network socket is connected. | 2014-01-06 14:03:44 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-01-06 14:03:44 TWS server version: 70 | 2014-01-06 14:03:44 IB: Connected. Waiting for account information. | 2014-01-06 14:03:44 IB Account information received. | 2014-01-06 14:03:44 Connected to IB Live account. | 2014-01-06 14:03:44 Next valid order ID: 1 | 2014-01-06 14:03:44 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2014-01-06 14:03:44 Message from IB: Market data farm connection is OK:eurofarm. IB Error Code: 2104. Request ID: -1. | 2014-01-06 14:03:44 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2014-01-06 14:03:44 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2014-01-06 14:03:44 Next valid order ID: 1 | 2014-01-06 14:03:44 IB Account information received. | 2014-01-06 14:03:44 Connected to IB Live account. | 2014-01-06 14:03:44 Mapping EUR-201403-GLOBEX to 6EH4. Service code: cme | 2014-01-06 14:03:44 SC Exchange Data - Starting real-time market data updates for: 6EH4 | 2014-01-06 14:03:44 SC Exchange Data: Connecting to the server scdf2.sierracharts.com. Port 443 | 2014-01-06 14:03:44 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-01-06 14:03:44 The network socket is connected. | 2014-01-06 14:03:45 SC Exchange Data: Connected to server. | 2014-01-06 14:03:45 SC Exchange Data: Sending logon request message. | 2014-01-06 14:03:45 HD Request # 3 - Downloading Intraday chart data for EUR-201403-GLOBEX to the file EUR-201403-GLOBEX.scid. Service: cme | 2014-01-06 14:03:45 HD Request # 3 - Download start Date-Time: 2014-01-03 22:59:56.0 | 2014-01-06 14:03:45 HD Request # 3 - Using server: scdf1.sierracharts.com port 10149 | 2014-01-06 14:03:45 Mapping ES-201403-GLOBEX to ESH4. Service code: cme | 2014-01-06 14:03:45 SC Exchange Data - Starting real-time market data updates for: ESH4 | 2014-01-06 14:03:45 HD Request # 4 - Downloading Historical Daily chart data for ESH14. Starting date: 2014-01-02. Service: ib | 2014-01-06 14:03:45 HD Request # 4 - Using user Barchart Historical data account. | 2014-01-06 14:03:45 HD Request # 4 - Requesting historical Daily data for ESH14 starting at 2014-01-01 | 2014-01-06 14:03:45 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-01-06 14:03:45 The network socket is connected. | 2014-01-06 14:03:45 HD Request # 3 - Sending historical data logon request message. | 2014-01-06 14:03:45 HD Request # 3 - Requesting up to 180 days of Intraday data. Record interval: 0 | 2014-01-06 14:03:46 HD Request # 3 - Decompressing data. | 2014-01-06 14:03:46 HD Request # 3 - Receiving Intraday data for EUR-201403-GLOBEX starting at 2014-01-03 22:59:56 | 2014-01-06 14:03:46 HD Request # 3 - Timestamp of first Intraday data file record written: 2014-01-06 00:00:00 | 2014-01-06 14:03:46 HD Request # 4 - Receiving historical Daily data for ESH14 starting at 2014-01-02 | 2014-01-06 14:03:47 Writing historical Daily data for ESH14 to the file ESH14.dly | 2014-01-06 14:03:47 HD Request # 4 - Received 3 records from 2014-01-02 00:00:00 to 2014-01-06 00:00:00 (5.0 days) and wrote 3 records for ESH14 | 2014-01-06 14:03:47 HD Request # 4 - Daily download COMPLETE for ESH14 | 2014-01-06 14:03:47 Date rule based rollover from ESM11 to next contract occurs at 2011-06-09 | 2014-01-06 14:03:47 Date rule based rollover from ESU11 to next contract occurs at 2011-09-08 | 2014-01-06 14:03:47 Date rule based rollover from ESZ11 to next contract occurs at 2011-12-08 | 2014-01-06 14:03:47 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08 | 2014-01-06 14:03:47 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07 | 2014-01-06 14:03:47 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13 | 2014-01-06 14:03:47 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13 | 2014-01-06 14:03:47 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07 | 2014-01-06 14:03:47 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13 | 2014-01-06 14:03:47 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12 | 2014-01-06 14:03:47 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12 | 2014-01-06 14:03:47 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13 | 2014-01-06 14:03:47 Checking Daily data file for symbol ESM11 for the date range from 2011-03-10 to 2011-06-04 | 2014-01-06 14:03:47 Checking Daily data file for symbol ESU11 for the date range from 2011-06-09 to 2011-09-03 | 2014-01-06 14:03:47 Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-03 | 2014-01-06 14:03:47 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-03 | 2014-01-06 14:03:47 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-02 | 2014-01-06 14:03:47 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-08 | 2014-01-06 14:03:47 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-08 | 2014-01-06 14:03:47 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-02 | 2014-01-06 14:03:47 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-08 | 2014-01-06 14:03:47 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-07 | 2014-01-06 14:03:47 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-07 | 2014-01-06 14:03:47 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to | 2014-01-06 14:03:47 Symbols used for ESH14 continuous contract chart: | 2014-01-06 14:03:47 ESM11 | 2014-01-06 14:03:47 ESU11 | 2014-01-06 14:03:47 ESZ11 | 2014-01-06 14:03:47 ESH12 | 2014-01-06 14:03:47 ESM12 | 2014-01-06 14:03:47 ESU12 | 2014-01-06 14:03:47 ESZ12 | 2014-01-06 14:03:47 ESH13 | 2014-01-06 14:03:47 ESM13 | 2014-01-06 14:03:47 ESU13 | 2014-01-06 14:03:47 ESZ13 | 2014-01-06 14:03:47 ESH14 | 2014-01-06 14:03:47 Volume based rollover from ESM11 to ESU11 occurs at 2011-06-10 | 2014-01-06 14:03:47 Volume based rollover from ESU11 to ESZ11 occurs at 2011-09-09 | 2014-01-06 14:03:47 The network socket for historical data has been closed. | 2014-01-06 14:03:47 Volume based rollover from ESZ11 to ESH12 occurs at 2011-12-09 | 2014-01-06 14:03:48 Volume based rollover from ESH12 to ESM12 occurs at 2012-03-09 | 2014-01-06 14:03:48 Volume based rollover from ESM12 to ESU12 occurs at 2012-06-08 | 2014-01-06 14:03:48 Volume based rollover from ESU12 to ESZ12 occurs at 2012-09-14 | 2014-01-06 14:03:48 Volume based rollover from ESZ12 to ESH13 occurs at 2012-12-14 | 2014-01-06 14:03:48 Volume based rollover from ESH13 to ESM13 occurs at 2013-03-08 | 2014-01-06 14:03:48 Volume based rollover from ESM13 to ESU13 occurs at 2013-06-14 | 2014-01-06 14:03:48 Volume based rollover from ESU13 to ESZ13 occurs at 2013-09-13 | 2014-01-06 14:03:48 Volume based rollover from ESZ13 to ESH14 occurs at 2013-12-13 | 2014-01-06 14:03:48 SC Exchange Data Server Info - Server Name: . Server Version: . Provider Name: . | 2014-01-06 14:03:48 SC Exchange Data - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-01-06 14:03:48 SC Exchange Data - Successfully connected. | 2014-01-06 14:03:48 Restarting real-time data updates for symbol: ES-201403-GLOBEX -> ESH4 | 2014-01-06 14:03:48 Restarting real-time data updates for symbol: EUR-201403-GLOBEX -> 6EH4 | 2014-01-06 14:03:48 HD Request # 3 - Received 39402 records from 2014-01-03 22:59:56 to 2014-01-06 14:03:28 (2.6 days) and wrote 39401 records for EUR-201403-GLOBEX | 2014-01-06 14:03:48 HD Request # 3 - Intraday download COMPLETE for EUR-201403-GLOBEX | 2014-01-06 14:03:49 Real-time Intraday chart data file updates started for EUR-201403-GLOBEX | 2014-01-06 14:03:49 HD Request # 5 - Downloading Intraday chart data for ES-201403-GLOBEX to the file ES-201403-GLOBEX.scid. Service: cme | 2014-01-06 14:03:50 HD Request # 5 - Download start Date-Time: 2014-01-03 23:14:59.0 | 2014-01-06 14:03:52 HD Request # 5 - Using server: scdf2.sierracharts.com port 10149 | 2014-01-06 14:03:52 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-01-06 14:03:52 Interactive Brokers: Requesting Trade Positions for account: U433559 | 2014-01-06 14:03:52 IB: Requesting historical order fills for account U433559 | 2014-01-06 14:03:52 No SC real-time data feed mapping found for symbol: EUR.USD-CASH-IDEALPRO | 2014-01-06 14:03:52 The network socket is connected. | 2014-01-06 14:03:52 HD Request # 5 - Sending historical data logon request message. | 2014-01-06 14:03:52 Interactive Brokers: Received Trade Positions download end message for account U433559 | 2014-01-06 14:03:52 Interactive Brokers: Received Open orders end message. | 2014-01-06 14:03:52 HD Request # 5 - Requesting up to 180 days of Intraday data. Record interval: 0 | 2014-01-06 14:03:52 SC Market Stats - Starting real-time market data updates for: $TQCK | 2014-01-06 14:03:52 SC Market Stats: Connecting to the server ds3.sierracharts.com. Port 443 | 2014-01-06 14:03:52 HD Request # 5 - Decompressing data. | 2014-01-06 14:03:53 HD Request # 5 - Receiving Intraday data for ES-201403-GLOBEX starting at 2014-01-03 23:14:59 | 2014-01-06 14:03:53 HD Request # 5 - Timestamp of first Intraday data file record written: 2014-01-03 23:14:59 | 2014-01-06 14:03:53 Mapping NQ-201403-GLOBEX to NQH4. Service code: cme | 2014-01-06 14:03:53 SC Exchange Data - Starting real-time market data updates for: NQH4 | 2014-01-06 14:03:53 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-01-06 14:03:53 The network socket for historical data has been closed. | 2014-01-06 14:03:53 HD Request # 5 - Received 720 records from 2014-01-03 23:14:59 to 2014-01-06 14:00:58 (2.6 days) and wrote 715 records for ES-201403-GLOBEX | 2014-01-06 14:03:53 HD Request # 5 - Intraday download COMPLETE for ES-201403-GLOBEX | 2014-01-06 14:03:54 Real-time Intraday chart data file updates started for ES-201403-GLOBEX | 2014-01-06 14:03:54 The network socket is connected. | 2014-01-06 14:03:54 SC Market Stats: Connected to server. | 2014-01-06 14:03:54 SC Market Stats: Sending logon request message. | 2014-01-06 14:03:54 HD Request # 6 - Downloading Intraday chart data for $TQCK to the file $TQCK.scid. Service: ddf | 2014-01-06 14:03:54 HD Request # 6 - Download start Date-Time: 2014-01-03 22:04:59.0 | 2014-01-06 14:03:55 HD Request # 6 - Using server: ds5.sierracharts.com port 10149 | 2014-01-06 14:03:55 SC Market Stats Server Info - Server Name: . Server Version: . Provider Name: . | 2014-01-06 14:03:55 SC Market Stats - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-01-06 14:03:55 SC Market Stats - Successfully connected. | 2014-01-06 14:03:55 Restarting real-time data updates for symbol: $TQCK | 2014-01-06 14:03:55 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-01-06 14:03:55 The network socket is connected. | 2014-01-06 14:03:55 HD Request # 6 - Sending historical data logon request message. | 2014-01-06 14:03:55 HD Request # 6 - Requesting up to 180 days of Intraday data. Record interval: 0 | 2014-01-06 14:03:55 HD Request # 6 - Decompressing data. | 2014-01-06 14:03:56 HD Request # 6 - Receiving Intraday data for $TQCK starting at 2014-01-03 22:04:59 | 2014-01-06 14:03:56 The network socket for historical data has been closed. | 2014-01-06 14:03:56 HD Request # 6 - Received 1 record from 2014-01-03 22:04:59 to 2014-01-03 22:04:59 (0.0 seconds) and wrote 0 records for $TQCK | 2014-01-06 14:03:56 HD Request # 6 - Intraday download COMPLETE for $TQCK | 2014-01-06 14:03:56 Real-time Intraday chart data file updates started for $TQCK | 2014-01-06 14:03:56 HD Request # 7 - Downloading Intraday chart data for NQ-201403-GLOBEX to the file NQ-201403-GLOBEX.scid. Service: cme | 2014-01-06 14:03:57 HD Request # 7 - Download start Date-Time: 2014-01-03 23:14:57.0 | 2014-01-06 14:03:57 HD Request # 7 - Using server: scdf1.sierracharts.com port 10149 | 2014-01-06 14:03:57 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-01-06 14:03:57 The network socket is connected. | 2014-01-06 14:03:57 HD Request # 7 - Sending historical data logon request message. | 2014-01-06 14:03:57 HD Request # 7 - Requesting up to 180 days of Intraday data. Record interval: 0 | 2014-01-06 14:03:57 HD Request # 7 - Decompressing data. | 2014-01-06 14:03:57 HD Request # 7 - Receiving Intraday data for NQ-201403-GLOBEX starting at 2014-01-03 23:14:57 | 2014-01-06 14:03:57 HD Request # 7 - Timestamp of first Intraday data file record written: 2014-01-06 00:00:00 | 2014-01-06 14:03:57 SC Market Stats - Starting real-time market data updates for: $TICK | 2014-01-06 14:03:57 The network socket for historical data has been closed. | 2014-01-06 14:03:58 HD Request # 7 - Received 10754 records from 2014-01-03 23:14:57 to 2014-01-06 14:03:52 (2.6 days) and wrote 10752 records for NQ-201403-GLOBEX | 2014-01-06 14:03:58 HD Request # 7 - Intraday download COMPLETE for NQ-201403-GLOBEX | 2014-01-06 14:03:58 Real-time Intraday chart data file updates started for NQ-201403-GLOBEX | 2014-01-06 14:03:58 HD Request # 8 - Downloading Intraday chart data for $TICK to the file $TICK.scid. Service: ddf | 2014-01-06 14:03:59 HD Request # 8 - Download start Date-Time: 2014-01-03 22:04:59.0 | 2014-01-06 14:03:59 HD Request # 8 - Using server: ds3.sierracharts.com port 10149 | 2014-01-06 14:03:59 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-01-06 14:03:59 The network socket is connected. | 2014-01-06 14:03:59 HD Request # 8 - Sending historical data logon request message. | 2014-01-06 14:03:59 HD Request # 8 - Requesting up to 180 days of Intraday data. Record interval: 0 | 2014-01-06 14:04:00 HD Request # 8 - Decompressing data. | 2014-01-06 14:04:00 HD Request # 8 - Receiving Intraday data for $TICK starting at 2014-01-03 22:04:59 | 2014-01-06 14:04:00 The network socket for historical data has been closed. | 2014-01-06 14:04:00 HD Request # 8 - Received 1 record from 2014-01-03 22:04:59 to 2014-01-03 22:04:59 (0.0 seconds) and wrote 0 records for $TICK | 2014-01-06 14:04:00 HD Request # 8 - Intraday download COMPLETE for $TICK | 2014-01-06 14:04:02 Real-time Intraday chart data file updates started for $TICK | 2014-01-06 14:04:02 Interactive Brokers - Starting real-time market data updates for: EUR.USD-CASH-IDEALPRO | 2014-01-06 14:04:02 Subscribing to real-time True Data for symbol: EUR.USD SecType: CASH Exchange: IDEALPRO Currency: USD | 2014-01-06 14:04:02 Subscribing to symbol: EUR.USD SecType: CASH Expiry: Exchange: IDEALPRO Currency: USD Multiplier: | 2014-01-06 14:04:02 No SC real-time data feed mapping found for symbol: EUR.USD-CASH-IDEALPRO | 2014-01-06 14:04:02 HD Request # 9 - Downloading Intraday chart data for EUR.USD-CASH-IDEALPRO to the file EUR.USD-CASH-IDEALPRO.scid. Service: ib | 2014-01-06 14:04:02 HD Request # 9 - Download start Date-Time: 2014-01-03 22:59:30.0 | 2014-01-06 14:04:02 HD Request # 9 - Requesting a total of 2 days and 59072 seconds. | 2014-01-06 14:04:02 HD Request # 9 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 145472. | 2014-01-06 14:04:02 HD Request # 9 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2014-01-04 22:49:30 for EUR.USD-CASH-IDEALPRO | 2014-01-06 14:04:02 Chart #6 has tagged chart #4 for full recalculation. Chartbook: ES_ZF_trade.scid.cht | 2014-01-06 14:04:02 Chart #6 has tagged chart #4 for full recalculation. Chartbook: ES_ZF_trade.scid.cht | 2014-01-06 14:04:02 Chart #6 has tagged chart #4 for full recalculation. Chartbook: ES_ZF_trade.scid.cht | 2014-01-06 14:04:02 Requesting market depth updates for: EUR.USD-CASH-IDEALPRO if supported. | 2014-01-06 14:04:03 Chart #4 is performing a full recalculation because it has been tagged. Chartbook: ES_ZF_trade.scid.cht | 2014-01-06 14:04:05 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:04:06 Chart #6 has tagged chart #1 for full recalculation. Chartbook: NQ_trade.cht | 2014-01-06 14:04:08 Chart #6 has tagged chart #1 for full recalculation. Chartbook: NQ_trade.cht | 2014-01-06 14:04:08 Chart #6 has tagged chart #1 for full recalculation. Chartbook: NQ_trade.cht | 2014-01-06 14:04:08 Message from IB: HMDS data farm connection is OK:cashhmds. IB Error Code: 2106. Request ID: -1. | 2014-01-06 14:04:09 Chart #1 is performing a full recalculation because it has been tagged. Chartbook: NQ_trade.cht | 2014-01-06 14:04:09 HD Request # 9 - Processing historical data message from TWS | 2014-01-06 14:04:18 HD Request # 9 - Received 2880 records and wrote 0 records from 2014-01-02 22:45:00 to 2014-01-03 22:59:30. | 2014-01-06 14:04:18 HD Request # 9 - IB Backfill - Seconds requested: 86400. Seconds Remaining: 59072. | 2014-01-06 14:04:20 HD Request # 9 - Requesting 1 Day of data at 30 secs with ending Date-Time at 2014-01-05 22:49:30 for EUR.USD-CASH-IDEALPRO | 2014-01-06 14:04:20 HD Request # 9 - Processing historical data message from TWS | 2014-01-06 14:04:22 HD Request # 9 - Received 2880 records and wrote 0 records from 2014-01-02 22:45:00 to 2014-01-03 22:59:30. | 2014-01-06 14:04:22 HD Request # 9 - IB Backfill - Seconds requested: 59072. Seconds Remaining: 0. | 2014-01-06 14:04:24 HD Request # 9 - Requesting 59072 Seconds of data at 30 secs with ending Date-Time at 2014-01-06 15:14:02 for EUR.USD-CASH-IDEALPRO | 2014-01-06 14:04:24 HD Request # 9 - Processing historical data message from TWS | 2014-01-06 14:04:25 HD Request # 9 - Timestamp of first Intraday data file record written: 2014-01-05 23:15:00 | 2014-01-06 14:04:25 HD Request # 9 - Received 1830 records and wrote 1779 records from 2014-01-03 22:34:30 to 2014-01-06 14:04:00. | 2014-01-06 14:04:25 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:04:26 HD Request # 9 - Received 7590 records and wrote 1779 records for EUR.USD-CASH-IDEALPRO | 2014-01-06 14:04:28 HD Request # 9 - Intraday download COMPLETE for EUR.USD-CASH-IDEALPRO | 2014-01-06 14:04:28 Real-time Intraday chart data file updates started for EUR.USD-CASH-IDEALPRO | 2014-01-06 14:04:28 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:05:42 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:05:42 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:05:43 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:05:43 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:05:44 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:05:44 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:05:45 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:05:57 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:05:57 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:05:58 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:06:01 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:06:04 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:06:04 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:06:05 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:06:06 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:06:08 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:06:08 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:06:09 Chart: NQ-201403-GLOBEX [M] 2 min #5 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 14:06:10 Unsubscribed from market depth data for EUR.USD-CASH-IDEALPRO | 2014-01-06 14:06:29 Requesting market depth updates for: NQ-201403-GLOBEX if supported. | 2014-01-06 14:06:29 Unsubscribed from market depth data for NQ-201403-GLOBEX | 2014-01-06 14:07:39 Requesting market depth updates for: ES-201403-GLOBEX if supported. | 2014-01-06 14:07:39 A request for the latest software update has been made. | 2014-01-06 14:09:15 The update is being downloaded in the background. When it is complete, you will be prompted. | 2014-01-06 14:09:15 There is no new version available. Thank you. | 2014-01-06 14:09:15 Date rule based rollover from ESM11 to next contract occurs at 2011-06-09 | 2014-01-06 14:10:14 Date rule based rollover from ESU11 to next contract occurs at 2011-09-08 | 2014-01-06 14:10:14 Date rule based rollover from ESZ11 to next contract occurs at 2011-12-08 | 2014-01-06 14:10:14 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08 | 2014-01-06 14:10:14 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07 | 2014-01-06 14:10:14 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13 | 2014-01-06 14:10:14 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13 | 2014-01-06 14:10:14 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07 | 2014-01-06 14:10:14 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13 | 2014-01-06 14:10:14 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12 | 2014-01-06 14:10:14 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12 | 2014-01-06 14:10:14 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13 | 2014-01-06 14:10:14 Checking Daily data file for symbol ESM11 for the date range from 2011-03-10 to 2011-06-04 | 2014-01-06 14:10:14 Checking Daily data file for symbol ESU11 for the date range from 2011-06-09 to 2011-09-03 | 2014-01-06 14:10:14 Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-03 | 2014-01-06 14:10:14 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-03 | 2014-01-06 14:10:14 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-02 | 2014-01-06 14:10:15 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-08 | 2014-01-06 14:10:15 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-08 | 2014-01-06 14:10:15 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-02 | 2014-01-06 14:10:15 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-08 | 2014-01-06 14:10:15 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-07 | 2014-01-06 14:10:16 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-07 | 2014-01-06 14:10:16 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to | 2014-01-06 14:10:16 Symbols used for ESH14 continuous contract chart: | 2014-01-06 14:10:16 ESM11 | 2014-01-06 14:10:16 ESU11 | 2014-01-06 14:10:16 ESZ11 | 2014-01-06 14:10:16 ESH12 | 2014-01-06 14:10:16 ESM12 | 2014-01-06 14:10:16 ESU12 | 2014-01-06 14:10:16 ESZ12 | 2014-01-06 14:10:16 ESH13 | 2014-01-06 14:10:16 ESM13 | 2014-01-06 14:10:16 ESU13 | 2014-01-06 14:10:16 ESZ13 | 2014-01-06 14:10:16 ESH14 | 2014-01-06 14:10:16 Volume based rollover from ESM11 to ESU11 occurs at 2011-06-10 | 2014-01-06 14:10:16 Volume based rollover from ESU11 to ESZ11 occurs at 2011-09-09 | 2014-01-06 14:10:16 Volume based rollover from ESZ11 to ESH12 occurs at 2011-12-09 | 2014-01-06 14:10:16 Volume based rollover from ESH12 to ESM12 occurs at 2012-03-09 | 2014-01-06 14:10:16 Volume based rollover from ESM12 to ESU12 occurs at 2012-06-08 | 2014-01-06 14:10:16 Volume based rollover from ESU12 to ESZ12 occurs at 2012-09-14 | 2014-01-06 14:10:16 Volume based rollover from ESZ12 to ESH13 occurs at 2012-12-14 | 2014-01-06 14:10:16 Volume based rollover from ESH13 to ESM13 occurs at 2013-03-08 | 2014-01-06 14:10:17 Volume based rollover from ESM13 to ESU13 occurs at 2013-06-14 | 2014-01-06 14:10:17 Volume based rollover from ESU13 to ESZ13 occurs at 2013-09-13 | 2014-01-06 14:10:17 Volume based rollover from ESZ13 to ESH14 occurs at 2013-12-13 | 2014-01-06 14:10:17 Date rule based rollover from EUR-201309-GLOBEX to next contract occurs at 2013-09-16 | 2014-01-06 14:10:18 Date rule based rollover from EUR-201312-GLOBEX to next contract occurs at 2013-12-16 | 2014-01-06 14:10:18 Date rule based rollover from EUR-201403-GLOBEX to next contract occurs at 2014-03-17 | 2014-01-06 14:10:18 Checking Intraday data file for symbol EUR-201309-GLOBEX for the date range from 2013-06-17 to 2013-09-16 | 2014-01-06 14:10:18 Checking Intraday data file for symbol EUR-201312-GLOBEX for the date range from 2013-09-16 to 2013-12-16 | 2014-01-06 14:10:18 Checking Intraday data file for symbol EUR-201403-GLOBEX for the date range from 2013-12-16 to | 2014-01-06 14:10:18 Symbols used for EUR-201403-GLOBEX continuous contract chart: | 2014-01-06 14:10:18 EUR-201309-GLOBEX | 2014-01-06 14:10:18 EUR-201312-GLOBEX | 2014-01-06 14:10:18 EUR-201403-GLOBEX | 2014-01-06 14:10:18 Date rule based rollover from E6M11 to next contract occurs at 2011-06-13 | 2014-01-06 14:10:18 Date rule based rollover from E6U11 to next contract occurs at 2011-09-19 | 2014-01-06 14:10:18 Date rule based rollover from E6Z11 to next contract occurs at 2011-12-19 | 2014-01-06 14:10:18 Date rule based rollover from E6H12 to next contract occurs at 2012-03-19 | 2014-01-06 14:10:18 Date rule based rollover from E6M12 to next contract occurs at 2012-06-18 | 2014-01-06 14:10:18 Date rule based rollover from E6U12 to next contract occurs at 2012-09-17 | 2014-01-06 14:10:18 Date rule based rollover from E6Z12 to next contract occurs at 2012-12-17 | 2014-01-06 14:10:18 Date rule based rollover from E6H13 to next contract occurs at 2013-03-18 | 2014-01-06 14:10:18 Date rule based rollover from E6M13 to next contract occurs at 2013-06-17 | 2014-01-06 14:10:18 Date rule based rollover from E6U13 to next contract occurs at 2013-09-16 | 2014-01-06 14:10:18 Date rule based rollover from E6Z13 to next contract occurs at 2013-12-16 | 2014-01-06 14:10:18 Date rule based rollover from E6H14 to next contract occurs at 2014-03-17 | 2014-01-06 14:10:18 Checking Daily data file for symbol E6M11 for the date range from 2011-03-14 to 2011-06-08 | 2014-01-06 14:10:18 Checking Daily data file for symbol E6U11 for the date range from 2011-06-13 to 2011-09-14 | 2014-01-06 14:10:18 Checking Daily data file for symbol E6Z11 for the date range from 2011-09-19 to 2011-12-14 | 2014-01-06 14:10:18 Checking Daily data file for symbol E6H12 for the date range from 2011-12-19 to 2012-03-14 | 2014-01-06 14:10:18 Checking Daily data file for symbol E6M12 for the date range from 2012-03-19 to 2012-06-13 | 2014-01-06 14:10:18 Checking Daily data file for symbol E6U12 for the date range from 2012-06-18 to 2012-09-12 | 2014-01-06 14:10:19 Checking Daily data file for symbol E6Z12 for the date range from 2012-09-17 to 2012-12-12 | 2014-01-06 14:10:19 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-13 | 2014-01-06 14:10:19 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-12 | 2014-01-06 14:10:19 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-11 | 2014-01-06 14:10:19 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-11 | 2014-01-06 14:10:19 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to | 2014-01-06 14:10:19 Symbols used for E6H14 continuous contract chart: | 2014-01-06 14:10:19 E6M11 | 2014-01-06 14:10:19 E6U11 | 2014-01-06 14:10:19 E6Z11 | 2014-01-06 14:10:19 E6H12 | 2014-01-06 14:10:19 E6M12 | 2014-01-06 14:10:19 E6U12 | 2014-01-06 14:10:19 E6Z12 | 2014-01-06 14:10:19 E6H13 | 2014-01-06 14:10:19 E6M13 | 2014-01-06 14:10:19 E6U13 | 2014-01-06 14:10:19 E6Z13 | 2014-01-06 14:10:19 E6H14 | 2014-01-06 14:10:19 Volume based rollover from E6M11 to E6U11 occurs at 2011-06-10 | 2014-01-06 14:10:19 Volume based rollover from E6U11 to E6Z11 occurs at 2011-09-16 | 2014-01-06 14:10:19 Volume based rollover from E6Z11 to E6H12 occurs at 2011-12-16 | 2014-01-06 14:10:19 Volume based rollover from E6H12 to E6M12 occurs at 2012-03-16 | 2014-01-06 14:10:19 Volume based rollover from E6M12 to E6U12 occurs at 2012-06-15 | 2014-01-06 14:10:19 Volume based rollover from E6U12 to E6Z12 occurs at 2012-09-14 | 2014-01-06 14:10:19 Volume based rollover from E6Z12 to E6H13 occurs at 2012-12-14 | 2014-01-06 14:10:19 Volume based rollover from E6H13 to E6M13 occurs at 2013-03-15 | 2014-01-06 14:10:19 Volume based rollover from E6M13 to E6U13 occurs at 2013-06-14 | 2014-01-06 14:10:19 Volume based rollover from E6U13 to E6Z13 occurs at 2013-09-13 | 2014-01-06 14:10:19 Volume based rollover from E6Z13 to E6H14 occurs at 2013-12-13 | 2014-01-06 14:10:19 No SC real-time data feed mapping found for symbol: EUR.USD-CASH-IDEALPRO | 2014-01-06 14:10:20 Date rule based rollover from E6U08 to next contract occurs at 2008-09-15 | 2014-01-06 14:10:20 Date rule based rollover from E6Z08 to next contract occurs at 2008-12-15 | 2014-01-06 14:10:20 Date rule based rollover from E6H09 to next contract occurs at 2009-03-16 | 2014-01-06 14:10:20 Date rule based rollover from E6M09 to next contract occurs at 2009-06-15 | 2014-01-06 14:10:20 Date rule based rollover from E6U09 to next contract occurs at 2009-09-14 | 2014-01-06 14:10:20 Date rule based rollover from E6Z09 to next contract occurs at 2009-12-14 | 2014-01-06 14:10:20 Date rule based rollover from E6H10 to next contract occurs at 2010-03-15 | 2014-01-06 14:10:20 Date rule based rollover from E6M10 to next contract occurs at 2010-06-14 | 2014-01-06 14:10:20 Date rule based rollover from E6U10 to next contract occurs at 2010-09-13 | 2014-01-06 14:10:20 Date rule based rollover from E6Z10 to next contract occurs at 2010-12-13 | 2014-01-06 14:10:20 Date rule based rollover from E6H11 to next contract occurs at 2011-03-14 | 2014-01-06 14:10:20 Date rule based rollover from E6M11 to next contract occurs at 2011-06-13 | 2014-01-06 14:10:20 Date rule based rollover from E6U11 to next contract occurs at 2011-09-19 | 2014-01-06 14:10:20 Date rule based rollover from E6Z11 to next contract occurs at 2011-12-19 | 2014-01-06 14:10:20 Date rule based rollover from E6H12 to next contract occurs at 2012-03-19 | 2014-01-06 14:10:20 Date rule based rollover from E6M12 to next contract occurs at 2012-06-18 | 2014-01-06 14:10:20 Date rule based rollover from E6U12 to next contract occurs at 2012-09-17 | 2014-01-06 14:10:20 Date rule based rollover from E6Z12 to next contract occurs at 2012-12-17 | 2014-01-06 14:10:20 Date rule based rollover from E6H13 to next contract occurs at 2013-03-18 | 2014-01-06 14:10:20 Date rule based rollover from E6M13 to next contract occurs at 2013-06-17 | 2014-01-06 14:10:20 Date rule based rollover from E6U13 to next contract occurs at 2013-09-16 | 2014-01-06 14:10:20 Date rule based rollover from E6Z13 to next contract occurs at 2013-12-16 | 2014-01-06 14:10:20 Date rule based rollover from E6H14 to next contract occurs at 2014-03-17 | 2014-01-06 14:10:20 Checking Daily data file for symbol E6U08 for the date range from 2008-06-16 to 2008-09-10 | 2014-01-06 14:10:20 Checking Daily data file for symbol E6Z08 for the date range from 2008-09-15 to 2008-12-10 | 2014-01-06 14:10:20 Checking Daily data file for symbol E6H09 for the date range from 2008-12-15 to 2009-03-11 | 2014-01-06 14:10:20 Checking Daily data file for symbol E6M09 for the date range from 2009-03-16 to 2009-06-10 | 2014-01-06 14:10:20 Checking Daily data file for symbol E6U09 for the date range from 2009-06-15 to 2009-09-09 | 2014-01-06 14:10:20 Checking Daily data file for symbol E6Z09 for the date range from 2009-09-14 to 2009-12-09 | 2014-01-06 14:10:21 Checking Daily data file for symbol E6H10 for the date range from 2009-12-14 to 2010-03-10 | 2014-01-06 14:10:21 Checking Daily data file for symbol E6M10 for the date range from 2010-03-15 to 2010-06-09 | 2014-01-06 14:10:21 Checking Daily data file for symbol E6U10 for the date range from 2010-06-14 to 2010-09-08 | 2014-01-06 14:10:21 Checking Daily data file for symbol E6Z10 for the date range from 2010-09-13 to 2010-12-08 | 2014-01-06 14:10:21 Checking Daily data file for symbol E6H11 for the date range from 2010-12-13 to 2011-03-09 | 2014-01-06 14:10:21 Checking Daily data file for symbol E6M11 for the date range from 2011-03-14 to 2011-06-08 | 2014-01-06 14:10:21 Checking Daily data file for symbol E6U11 for the date range from 2011-06-13 to 2011-09-14 | 2014-01-06 14:10:21 Checking Daily data file for symbol E6Z11 for the date range from 2011-09-19 to 2011-12-14 | 2014-01-06 14:10:21 Checking Daily data file for symbol E6H12 for the date range from 2011-12-19 to 2012-03-14 | 2014-01-06 14:10:21 Checking Daily data file for symbol E6M12 for the date range from 2012-03-19 to 2012-06-13 | 2014-01-06 14:10:22 Checking Daily data file for symbol E6U12 for the date range from 2012-06-18 to 2012-09-12 | 2014-01-06 14:10:22 Checking Daily data file for symbol E6Z12 for the date range from 2012-09-17 to 2012-12-12 | 2014-01-06 14:10:22 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-13 | 2014-01-06 14:10:22 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-12 | 2014-01-06 14:10:22 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-11 | 2014-01-06 14:10:22 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-11 | 2014-01-06 14:10:22 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to | 2014-01-06 14:10:22 Symbols used for E6H14 continuous contract chart: | 2014-01-06 14:10:22 E6U08 | 2014-01-06 14:10:22 E6Z08 | 2014-01-06 14:10:22 E6H09 | 2014-01-06 14:10:22 E6M09 | 2014-01-06 14:10:22 E6U09 | 2014-01-06 14:10:22 E6Z09 | 2014-01-06 14:10:22 E6H10 | 2014-01-06 14:10:22 E6M10 | 2014-01-06 14:10:22 E6U10 | 2014-01-06 14:10:22 E6Z10 | 2014-01-06 14:10:22 E6H11 | 2014-01-06 14:10:22 E6M11 | 2014-01-06 14:10:22 E6U11 | 2014-01-06 14:10:22 E6Z11 | 2014-01-06 14:10:22 E6H12 | 2014-01-06 14:10:22 E6M12 | 2014-01-06 14:10:22 E6U12 | 2014-01-06 14:10:22 E6Z12 | 2014-01-06 14:10:22 E6H13 | 2014-01-06 14:10:22 E6M13 | 2014-01-06 14:10:22 E6U13 | 2014-01-06 14:10:22 E6Z13 | 2014-01-06 14:10:22 E6H14 | 2014-01-06 14:10:22 No SC real-time data feed mapping found for symbol: EUR.USD-CASH-IDEALPRO | 2014-01-06 14:10:23 Chart #6 has tagged chart #4 for full recalculation. Chartbook: ES_ZF_trade.scid.cht | 2014-01-06 14:10:23 Chart #6 has tagged chart #4 for full recalculation. Chartbook: ES_ZF_trade.scid.cht | 2014-01-06 14:10:23 Chart #6 has tagged chart #1 for full recalculation. Chartbook: NQ_trade.cht | 2014-01-06 14:10:23 Chart #6 has tagged chart #1 for full recalculation. Chartbook: NQ_trade.cht | 2014-01-06 14:10:23 Chart #1 is performing a full recalculation because it has been tagged. Chartbook: NQ_trade.cht | 2014-01-06 14:10:24 Chart #4 is performing a full recalculation because it has been tagged. Chartbook: ES_ZF_trade.scid.cht | 2014-01-06 14:10:24 Unsubscribed from market depth data for ES-201403-GLOBEX | 2014-01-06 14:11:04 Requesting market depth updates for: NQ-201403-GLOBEX if supported. | 2014-01-06 14:11:04 Unsubscribed from market depth data for NQ-201403-GLOBEX | 2014-01-06 14:11:14 Requesting market depth updates for: ES-201403-GLOBEX if supported. | 2014-01-06 14:11:14 Uploaded an image to |
Private File Private File Attachment Deleted. |
| [2014-01-06 20:32:31] |
We are testing your Chartbook now and we cannot duplicate the problem. We see no exceptions occurring. So not quite sure what we can do at the moment about this. It is also hard to believe an exception is actually occurring because we have never seen that before from that particular function. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-01-06 22:07:26] |
| User57821 - Posts: 18 |
Chart: ES-201403-GLOBEX [M] 2 min #4 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 15:06:59 Chart: ES-201403-GLOBEX [M] 2 min #4 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 15:07:00 Chart: ES-201403-GLOBEX [M] 2 min #4 | Study: Volume By Price | Exception occurred while calling study function. | 2014-01-06 15:07:00 Date Time Of Last Edit: 2014-01-23 22:00:47
| [2014-01-06 22:59:30] |
Hello, I am always open at the same time two chartbooks with the same settings. First is ES_ZF_trade.scid.cht, I copied this chartbook from the second installation with the original settings for Zen-Fire to Interactive Brokers installation. In contrast to the second chartbook NQ_trade.cht, which I created directly in IB installation by copying graphs, has .scid extension. I think the problem does only this scid chartbook. It may be the reason? Why NQ chartbook is only .cht file without extension, while also contains intraday data? I may have not copied all necessary from previous Zen-Fire instance? Martin
Private File |
| [2014-01-23 22:01:52] |
We think we have an idea what is causing this problem now. Are you using the Peaks and Valleys lines with the Volume by Price study? We have another report like this one. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-01-24 09:05:40] |
Input Name/Input Value Draw Peaks & Valleys/Both P&V Extend P&V/None Highlight VA/Yes Extend VA/None |
| [2014-01-29 17:47:11] |
OK thank you for this. We will be checking on this.
| [2014-01-29 21:16:40] |
Hello, your idea has been right the problem was really in enable Peaks&Valleys. I set input value = None and now is all o.k. No problem. Thank you. Martin
