Date/Time: Sun, 04 Oct 2026 01:22:18 +0000
How To Stretch/Shrink The Scale Of Indicators?
View Count: 1251
| [2019-12-15 09:58:04] |
| Alberto Gauer - Posts: 121 |
Hi there. Do you know how you can stretch or shrink price bars when you click and hold the scale using the hand tool and moving the mouse up or down? Well I tried to do that on the volume indicator so I can stretch/zoom in (because the overnight volume gets dwarfed by the NY session volume), but it does not work, it is locked. If I right click on the volume scale it just show me the price chart scale settings. I don´t know where to go in options to fix this, please help. Thanks |
| [2019-12-15 13:16:02] |
Your Sierra Chart account is expired. Do you have an active paid Sierra Chart account?
| [2019-12-15 14:12:59] |
It has been expired for ages, I use Sierra from broker.
| [2019-12-15 14:29:11] |
Guys, if anyone can´t find the option, I found it: Just go to study settings and click "scale", haven´t noticed that button in there. Then you can set the scale mode of indicator´s region. |
| [2019-12-15 16:49:35] |
You need to log into your Sierra Chart account with Help >> Support Board. Otherwise, we do not provide support for expired accounts.
