Date/Time: Sat, 18 May 2024 16:32:49 +0000
Bid Ask Depth Bars v2 Stopped Working on ES - Denali
View Count: 1232
[2019-12-23 04:04:41] |
We are not observing any problem after an extended test and we think maybe you are running an older version. Make sure Sierra Chart is up-to-date with the installation that has this issue: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-23 23:13:29] |
zippyzip - Posts: 293 |
the depth bars should definently be fixed if your going to offer them to use with cqg, RT and ninja, bookmap are ofering depth bars now so since you paved the way for them then maybe they need to work correct .
