Date/Time: Fri, 06 Nov 2026 08:40:51 +0000
TPO imbalance
View Count: 2095
| [2019-11-18 06:36:13] |
| Csurles2010 - Posts: 13 |
Hello, I am looking for a study to calculate the tpo imbalance. I found a similar study with "tpos above/below poc". Is there any way possible to exclude single print tpos at the extremes from this calculation? I would like this calculation to only include rows (within the full range) with 2 or more tpos as a way to get imbalance without the distortion an excess (buy/sell) tail can create. Is it possible that Sierra charts can calculate this value on a per profile basis? Thank you |
| [2019-11-19 03:46:29] |
So you need to be able to have the TPOs above and below the point of control, to exclude singles? It already is calculated per TPO profile. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-10-29 21:11:25] |
| User337568 - Posts: 65 |
I am looking to Count or Highlight TPO single prints. Do we have anything for this? Date Time Of Last Edit: 2021-10-29 21:11:43
| [2021-10-31 15:50:12] |
| John - SC Support - Posts: 48449 |
Refer to the following Input for the TPO study: Time Price Opportunity (TPO) Profile Charts: Extend Singles For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
