Date/Time: Sat, 03 Oct 2026 21:20:49 +0000
Issue with CL rollover from Z9 to F0 on Rithmic
View Count: 878
| [2019-11-18 01:56:01] |
| User716661 - Posts: 13 |
Trying to rollover from CLZ19 to CLF20 on Rithmic (contract name CLZ9-NYMEX -> CLF0-NYMEX) but rollover fails / sets current contract to CLF2 or CLG4. Maybe a problem with the symbol setting? Thanks for your help
| [2019-11-18 02:52:06] |
This is already resolved. You need to update Sierra Chart to the current version. Instructions: Software Download: Fast Update After the update just correct the symbol in the Chart >> Chart Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-18 02:59:38
