Date/Time: Sat, 03 Oct 2026 21:21:25 +0000
Needing real time Futures Market Depth Data
View Count: 973
| [2019-11-13 15:27:36] |
| User721518 - Posts: 2 |
Hi, i'm currently with AMP futures and have a funded account with them. However, the market depth only gives me up to 10 levels at best, with the exception of CL contracts. I guess i'll be needing the Sierra Chart real time exchange data. My question is, if i terminate the subscription to the data feed for CME on AMP itself, because i do not want to be charged double (15.75 USD x 2), will i still be able to submit orders to AMP? or must i have the subscription to the data exchange on AMP itself as well as Sierra Chart real time futures data to be able to see full market depth together with being able to submit live orders? Does this apply to the other exchanges as well? I need connectivity and full depth of the HKFE exchange as well. Thank you for the help |
| [2019-11-13 18:04:56] |
. My question is, if i terminate the subscription to the data feed for CME on AMP itself, because i do not want to be charged double (15.75 USD x 2), will i still be able to submit orders to AMP? Yes. This is still true with any exchange.You do not need to pay for any market data through your broker. You can obtain all of it through Sierra Chart provided data feeds. This is the data feed you will want to use if you also require HKFE: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-17 03:18:59
