Date/Time: Sat, 03 Oct 2026 21:21:22 +0000
Rolling based on volume after inactive time
View Count: 773
| [2019-11-13 07:15:02] |
| arruga - Posts: 253 |
Hi It's been a couple of months that I didn't use Sierra. I am connected to IB... I got global settings set to roll based on volume detection. All my charts are loading the Sep contracts, they did not roll. Please advise thanks |
| [2019-11-13 17:27:06] |
You have to manually do this. Refer to the instructions here: Changing to a New Futures Contract Month Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
