Date/Time: Sat, 03 Oct 2026 21:21:25 +0000
How can I check a support for the native order types ?
View Count: 765
[2019-11-13 07:10:33]
R1sk - Posts: 259
For example is a native stop limit order type supported by the Nymex CL contracts (WTI Crude Oil futures) ?
Then if the exchange will support a native order type is it allways automatically supported by the platform ?
I am using CQG.
(Native = orders are sitting in the queue at the exchange)
[2019-11-13 18:03:04]
In the case of a Stop-Limit order that will go to the exchange.
Refer to the following for the order types that Sierra Chart supports:
Order Types
