Date/Time: Sat, 03 Oct 2026 20:19:30 +0000
Deribit API
View Count: 1308
| [2019-11-12 19:36:09] |
| User661434 - Posts: 27 |
Hi, I read that Sierra can be used with Deribit exchange. Is it only for charting or can trades be done directly as well (just like Bitmex, directly form the charts) Are you thinking of doing this also with Binance? Thanks for looking at this |
| [2019-11-13 01:32:39] |
Sierra Chart only supports market data from Deribit. Not trading functionality. There are no plans for Binance at this time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
