Date/Time: Sat, 03 Oct 2026 20:19:39 +0000
Midpoint Letter
View Count: 1111
[2019-11-11 19:41:35]
steve greene - Posts: 6
This is probably simple, but for whatever reason I can't find it, remember the setting or figure it out. I want to highlight the Midpoint "letter" on my TPO chart but I don't want the the highlighted square box around it. I can get the box but I can't figure out to ONLY highlight the letter. Ideas?
[2019-11-12 19:22:34]
John - SC Support - Posts: 48095
To highlight the Midpoint of the entire profile, refer to the following TPO Input:
Time Price Opportunity (TPO) Profile Charts: Highlight Midpoint in Profile
But, since you reference the ability to draw the square, it makes us wonder if you are really referring to the midpoint of each sub-period, which you can highlight with a square around it. That is the only option to highlight each sub-period midpoint. Refer to the following:
Time Price Opportunity (TPO) Profile Charts: Highlight Sub Period Midpoint Letter/Block
[2019-11-12 20:45:29]
Yeah I was referring to each sub period which I realized, with sub periods there's only the ability to outline/"highlight" with a square. There is not the ability to "highlight" and or change the color of that letter. That's ok, I went back to the square, but a letter highlight like we're able to do with the "start" of a new sub period would be nice, maybe in the future?
