Date/Time: Sat, 03 Oct 2026 20:19:38 +0000
cannot connect
View Count: 854
| [2019-11-08 15:41:19] |
| User590837 - Posts: 1 |
Hello, I have real account with rithmic data feed. Just instaled Sierra with trial. Got this error: Error running DTC server program C:/Sierrachart/Rim/DTCBridge.exe. Actually I don't have such folder "Rim" at my computer.
| Attachment Deleted. |
| [2019-11-08 17:12:04] |
That particular program is not installed by default. Install Sierra Chart again by selecting Help >> Download Current Version. On the Installation window select the option for Install Optional Components before beginning the installation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-08 17:12:39
