Date/Time: Wed, 25 Nov 2026 07:55:47 +0000
[Programming Help] - basic acsil - how to write message to a log (from within CustomChartBarFunction)
View Count: 5316
| [2019-11-06 16:13:03] |
| ochocinco - Posts: 29 |
This is a basic acsil help request. Im certain there is a simple concept I'm missing. What is the right way to add a message to a log from within the "CustomFunction" function? Im using Remote Build. The output is: debug_test.cpp: In function 'void CustomFunction(SCCustomChartBarInterfaceRef)': debug_test.cpp:10:4: error: 'sc' was not declared in this scope sc.AddMessageToLog(DebugMessage, 0); ^ This code below is only used as a compile test, not to actually build custom chart bars. #include "sierrachart.h"
SCDLLName("debug example") SCSFExport CustomFunction(SCCustomChartBarInterfaceRef ChartBarInterface) { ChartBarInterface.StartNewBarFlag = 0; if (ChartBarInterface.IsDeterminingIfShouldStartNewBar) { SCString DebugMessage; DebugMessage.Format("Hello World #1"); sc.AddMessageToLog(DebugMessage, 0); return; } } SCSFExport scsf_CustomChartBarsExample(SCStudyInterfaceRef sc) { if (sc.SetDefaults) { // This function is called from another thread. sc.fp_ACSCustomChartBarFunction = CustomFunction; sc.AutoLoop = 0;//Always use manual looping. return; } } thanks for your consideration, |
| [2019-11-07 10:23:45] |
| User907968 - Posts: 887 |
The function needs to be passed reference to sc structure - ACSIL Programming Concepts: Passing ACSIL Interface Members Structure To Secondary Function But, for CustomChartBarFunction, I don't think this is possible. sc.fp_ACSCustomChartBarFunction expects pointer to function only one variable 'SCCustomChartBarInterfaceRef' |
| [2019-11-07 10:36:20] |
I'd wondered about that. Thanks very much for taking the time to reply.
| [2019-11-08 01:33:26] |
This function: sc.AddMessageToLog Is not contained within: SCCustomChartBarInterfaceRef Although we could add it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-11-08 12:12:00] |
I'm trying to debug my custom chart bars code, so if the AddMessageToLog function can be added within SCCustomChartBarInterfaceRef that would be great.
| [2020-06-01 05:53:41] |
| User806682 - Posts: 27 |
Just following up on this thread. I see this member function isn't yet available in SCCustomChartBarInterfaceRef. Could you guys please add AddMessageToLog please? |
| [2025-09-18 12:25:03] |
| robrg2675 - Posts: 22 |
Following up on this old post, was the AddMessageToLog function added within SCCustomChartBarInterfaceRef?
