Date/Time: Sat, 03 Oct 2026 21:19:52 +0000
Indicator Support
View Count: 1195
| [2019-10-30 05:32:12] |
| User688457 - Posts: 9 |
Dear Sierra Chart, I never got a response to my last inquiry, but it was involving a Volume weighted Accumulation/ Distribution study. I tried to adjust the settings, but i wasnt successful. I tried to get the study to plot similar to the study in the picture in the attachment. The study in the attachment is from a different platform, but its the closest thing i could find to what i am trying to get the Accumulation/Distribution study to plot and look like visually. Can you help please. As this is a vital part of my trading strategy. |
| [2019-10-30 11:58:27] |
Do you have a formula for the study that you require?
| [2019-10-30 14:15:48] |
((Close – Low) – (High – Close)) / (High – Low) * Period Volume
| [2019-10-30 18:18:36] |
| Vivil - Posts: 7 |
Is it that what you mean? (see attachment) double Vol = 0; double hi = (double)sc.High[sc.Index-1]; double lo = (double)sc.Low[sc.Index-1]; double op = (double)sc.Open[sc.Index-1]; double cl = (double)sc.Close[sc.Index-1]; for (int i = sc.Index -1; i > sc.Index - 1 - In_VolumePeriode.GetInt(); i--) { Vol += sc.Volume[sc.Index]; } double dValue = ((cl-lo) - (hi-cl))/(hi-lo)*Vol; sg_Indikator[sc.Index] = dValue; Date Time Of Last Edit: 2019-10-30 20:09:00
| [2019-10-30 18:44:42] |
I added the file to the data folder, and when i tried to pull file up on sierra charts the message in the attachment is what i got. And i also saw under my account that my account was not enabled for dll files. And that i need to contact support team Date Time Of Last Edit: 2019-10-30 18:56:22
| [2019-10-30 19:09:49] |
| Vivil - Posts: 7 |
I think it was my problem. And you need the newest (2005 but min 2002!) Version Sierra-chart when you can't update absolutely - so I need your Version! See screenshot... Date Time Of Last Edit: 2019-10-30 21:19:47
| [2019-10-30 19:35:30] |
My version is Sierra Chart 1991. Im currently downloading updated version Date Time Of Last Edit: 2019-10-30 19:37:27
| [2019-10-30 19:42:05] |
OK. I have current 2005 version now, and i was able to pull indicator up and everything looks great. Thank you very much. Its awesome Date Time Of Last Edit: 2019-10-30 19:42:37
| [2019-10-30 20:08:10] |
| Vivil - Posts: 7 |
It's fine. Can you verify the data of study? Is all right?
Date Time Of Last Edit: 2019-10-30 20:34:36
| [2019-11-05 23:29:57] |
| SC Support Tom - Posts: 450 |
It's fine. Can you verify the data of study? Is all right? I can verify if the data is all right in a spreadsheet, but when I add the .dll file to my Sierra Chart/Data folder, the ACS does not show up. I am using Version 2007. Have you restricted this .dll file to User688457's account only? Date Time Of Last Edit: 2019-11-05 23:30:20
| [2019-11-06 12:28:47] |
| Vivil - Posts: 7 |
hi... his become the "beta"version without restrictions. But there was a bug inside. I added restrictions to manage the User and force updates... Please send me your SC-Username. I add you in the list and You become the newest Version.... |
| [2019-11-13 20:26:39] |
Hi, my SC username is SC Support Tom (same as on the board). Thanks!
