Date/Time: Sat, 03 Oct 2026 18:42:27 +0000
Triggered order cancels all other orders ..
View Count: 1036
| [2019-10-27 22:08:55] |
| User355317 - Posts: 12 |
Hi. Is there a way to automatically have all pending orders canceled after a single order has been triggered? For example. If I pre-place 2 opposite pre-orders, at the same time for one stock, one order will be buying the other order will be selling, to where if price goes up, hits my desired price and gets triggered, or, if price goes down and my sell order is triggered, is there a way to automatically and instantly have all other existing pending orders cancelled, once that one order is triggered? Thanks. |
| [2019-10-28 11:31:13] |
Yes what you want is fully supported through the different OCO order types on this page: Order Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
