Date/Time: Sat, 03 Oct 2026 23:21:22 +0000
Write Bar and Study Data to File -- Path and Filename Location
View Count: 2127
[2019-10-24 09:17:39]
User025822 - Posts: 35
I have been unable to save the file from the Write Bar and Study Data to File study to a folder location outside the SierraChart folder.
By default it saves to C:\SierraChart\Data and I can also point it to any folder that I specify inside the SierraChart folder but i would like it to save to a custom location ie.. C:\Datafiles.
Every time I point the Path and File name to C:\Datafiles\BarStudyData_YM_5m.csv I see that in the Log file Sierra had reset the location to the folder C:\SierraChart\Data\BarStudyData_YM_5m.csv
Is it possible to use a different folder outside of the SierraChart folder to save the study Write Bar and Study Data to File ???
Thank you
imageWrite Bar and Study Data.png / V - Attached On 2019-10-24 09:14:56 UTC - Size: 43.06 KB - 496 views
imageWrite Bar and Study Data LOG.png / V - Attached On 2019-10-24 09:15:07 UTC - Size: 3.61 KB - 430 views
[2019-11-27 15:21:51]
Hi.
Any comment on this please..
Thank you
[2019-11-29 16:24:00]
We will look into this.
[2019-11-29 16:40:30]
We are unable to reproduce this:
The specified path does remain and there is no change to it.
Date Time Of Last Edit: 2019-11-29 16:40:40
