Date/Time: Sat, 27 Apr 2024 03:46:13 +0000
adjusting width of the y vertical axis
View Count: 665
[2019-10-17 18:30:50] |
You cannot adjust the width of the Price scale. It is set automatically. If you are having a problem with something being displayed, please let us know what that specifically is.
