Date/Time: Wed, 08 May 2024 01:03:59 +0000
Sierra Chart on macOS with wine
View Count: 8684
[2021-02-25 23:19:49] |
Though, there is an issue with a data update. After the system restarts or disconnects, SierraChart automatically downloads missed data and append it. This doesn't work in CrossOver for some reason, and I'm forced to Delete and Download All Data every time I close my notebook. Does anybody know how I can fix this issue? Refer to:Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Error when Downloading Historical Intraday Data from the Sierra Chart Historical Data Server Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-27 21:06:59] |
User840539 - Posts: 21 |
Hi there! New to Sierra Charts using Crossover. While installing there was a note: the version being installed is Non-CLR. Limitations: does not work with BarChart services. the question is: will Numbers Bar work? Are they part of BarChart services? Or they run just fine? Thank you! |
[2021-02-27 21:26:37] |
GravisHTG - Posts: 303 |
I had Sierra charts on mac M1 with crossover and Everything worked just fine.
[2021-02-28 00:12:42] |
the question is: will Numbers Bar work? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-02 03:48:48] |
d9e5c763 - Posts: 84 |
The removal of MFC will be finished before June 2021 and then we can begin to adapt Sierra Chart directly to Linux or perhaps we may just utilize WINE and get involved in working out the bugs that exist by fixing that code. That is another potential approach.
Can you share more details about porting to linux or other operating systems, such as the compatibility of X11 and Wayland, which widget toolkit you plan to use or not, the priority of this work in your to-do list? |
[2022-02-18 13:33:53] |
User978290 - Posts: 25 |
Hi, I'm using the latest Crossover on M1 mac. Everything works fine and feels native. I can almost make a full transition form pc to mac. However, during replays / backtest when I open position, the Time in Activity Log is always at system time and not the actual chart time. Making analysing a year backtest impossible cause all entry is current time. is there an easy fix like install a package? |
[2022-02-18 14:53:21] |
However, during replays / backtest when I open position, the Time in Activity Log is always at system time and not the actual chart time. This is not related to the operating system. This is a recent change. Update to the latest prerelease:Software Download: Fast Update There are two Date-Time columns now in the Trade Activity Log. You will want to look at Transaction Date-Time for the time that matches the bar times in the chart during a replay. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-18 14:57:33] |
Actually we see a problem with the Transaction Date-Time column still showing the same Date-Time. We are checking on this now.
[2022-02-19 03:22:17] |
Regarding post #82, update to latest prerelease: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-19 07:17:02] |
Pre release confirmed working! thx for the quick update |
