Date/Time: Tue, 17 Nov 2026 16:32:38 +0000
[Programming Help] - Order.Stop1InternalOrderID = 0 in LIVE trading?
View Count: 1652
[2019-09-03 06:19:21]
tomas262 - Posts: 164
I am adjusting Stop1Order for a trade open with ACSIL. When using SIM / REPLAY mode everything works great. Once a trade is open Stop1InternalOrderID is set for example to value 14695 so ID is non-zero and order can be modified successfully
But when I switch to live trading and open a trade with the same code Stop1InternalOrderID is always 0 so the order cannot be selected to modify
With the very same code what could be the reason? Trade LIVE & REPLAY screenshot attached
Also attaching executed orders table with IDs shown
This opened the sell trade:
s_SCNewOrder NewOrder;
NewOrder.OrderQuantity = OCO1Size.GetInt() + OCO2Size.GetInt() + OCO3Size.GetInt();
NewOrder.OrderType = SCT_ORDERTYPE_MARKET;
NewOrder.TimeInForce = SCT_TIF_GOOD_TILL_CANCELED;
int Result = (int)sc.SellEntry(NewOrder);
if (Result > 0)
  EntryOrderID = NewOrder.InternalOrderID;
  Target1OrderID = NewOrder.Target1InternalOrderID;
  Stop1OrderID = NewOrder.Stop1InternalOrderID;
This is how I move to B/E
// Get and move the existing SL 1 order
s_SCTradeOrder ExistingStopOrder1;
if (sc.GetOrderByOrderID(Stop1OrderID, ExistingStopOrder1) != SCTRADING_ORDER_ERROR)
  if (IsWorkingOrderStatus(ExistingStopOrder1.OrderStatusCode))
    double NewStop = 0.0;
    if (ExistingStopOrder1.BuySell == BSE_SELL) {
      NewStop = PositionData.AveragePrice + (double)BE1OffsetTicks.GetInt() * sc.TickSize;
    s_SCNewOrder ModifyStopOrder1;
    ModifyStopOrder1.InternalOrderID = Stop1OrderID;
    ModifyStopOrder1.Price1 = NewStop;
    if (sc.ModifyOrder(ModifyStopOrder1) != SCTRADING_ORDER_ERROR) {
      logMessage.Format("SL 1 order moved to BE");
      if (LogMessages.GetYesNo() == 1) sc.AddMessageToLog(logMessage, 1);
    else {
      logMessage.Format("Error modifying SL 1 order, ID: %u", Stop1OrderID);
  moveBE1triggered = 1;
Thanks for your great support!
Date Time Of Last Edit: 2019-09-03 06:27:42
imagelive-trade.png / V - Attached On 2019-09-03 06:16:44 UTC - Size: 141.33 KB - 488 views
imagesim-trade.png / V - Attached On 2019-09-03 06:16:48 UTC - Size: 158.84 KB - 416 views
imageorders-live.png / V - Attached On 2019-09-03 06:22:32 UTC - Size: 139.44 KB - 397 views
[2019-09-03 11:30:25]
Seems the code is working differently in live mode - executing part of code which resets IDs to 0. Does not happen in SIM. Very strange
imagereset-0.png / V - Attached On 2019-09-03 11:30:14 UTC - Size: 144.8 KB - 397 views
[2019-09-03 13:08:34]
Solved, found a glitch within the code, strangely did not happen on sim
