Date/Time: Tue, 17 Nov 2026 16:32:27 +0000
Period OHLC - Variable period - Setting previous monthly lows/highs
View Count: 2224
| [2019-08-31 19:52:21] |
| Oxcap - Posts: 81 |
Hello, I set up previous weekly and monthly highs/lows using the period OHLC-Variable period study. I use this study on a 1600 tick chart. It currently doesn't show the monthly levels. Can you assist with see what the issue might be? I've attached screen shots. Thanks |
| Attachment Deleted. |
| [2019-08-31 20:19:48] |
| User316362 - Posts: 215 |
These settings seem to work for me on 1600 and also show current month...
| [2019-08-31 20:42:37] |
| Oxcap - Posts: 81 |
When i use those settings you provided..it shows current monthly only but doesn't show previous month.
| [2019-08-31 20:46:04] |
| Oxcap - Posts: 81 |
One other thing is that I use the same settings i currently use on a 15minute monthly chart..It plots it there but the price is off by a couple points. Do you experience this issue? For example, ES monthly high is 2955.5 for July. On my chart it plots 2958.
| [2019-09-01 00:36:48] |
In my settings above for a 1600 tic chart. You can see (Capture2 attached) the values at the turn of the month of July/August when I scroll back. So it is working for multiple months. Also, the values for august are correct and also the ones for July are correct and match my daily charts. The high for July is 3029.50 for July for ESU19. you can see value in Cature3 below. You may want to check your chart settings (Capture4) to see if you are including overnight? your times don't have to be the same of course but make sure you are including 24 hour timeframe Date Time Of Last Edit: 2019-09-01 00:39:01
| [2019-09-01 19:59:01] |
| Oxcap - Posts: 81 |
thank this helped. I saw that you had 400 days loaded in setting. I adjust that and it shows correctly now.
| [2019-09-04 08:42:34] |
The documentation has been updated in regards to this. You do have to make sure the chart is loading sufficient data to perform the calculations by the study.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-04 08:42:54
