Date/Time: Fri, 13 Nov 2026 23:16:34 +0000
Spreadsheet Functions
View Count: 10616
| [2013-07-30 18:07:28] |
You are not posting in the correct place. You need to start a new thread about this.
| [2013-10-19 22:04:15] |
| namlem - Posts: 94 |
Hi SC team, I found that INDIRECT function is missing. Actually I need it very much. Would appreciate if you add it. Thank you. |
| [2013-10-20 01:48:12] |
| batman_ - Posts: 190 |
Chase limit function and allows user to define chase entry limit order by tick away from current price.
| [2013-10-21 12:10:12] |
harimau muda, as far as I understand in my case it doesn't help. I neither don't have opened trades nor it's in real time. I use this function to go through the history and do analysis.
| [2014-12-14 07:51:56] |
| enemyspy - Posts: 307 |
Can you also please add the NOT function in a future release if possible.
| [2014-12-17 03:49:18] |
We will add this function.
| [2014-12-17 07:40:06] |
| Marmany - Posts: 319 |
I use spreadsheet as a scanner on futures markets. Evaluating new spreadsheet sc v1217. When an area is highlighted and right clicked the sort function is "greyed out". Is it possible to activate manual sorting in the new spreadsheets. Please advise |
| [2014-12-17 10:16:19] |
No. The new Spreadsheets do not support sorting. We do not foresee adding this capability for a long time.
| [2014-12-17 11:47:12] |
Please continue to allow updated versions of Sierra to access the Old Spreadsheets until the sorting capability is added. Many thanks |
| [2023-05-20 22:27:03] |
| Chad - Posts: 247 |
Hi SCE, could you add some spreadsheet functions like Excel has for distribution fit/test? e.g. BETA.DIST CHISQ.DIST EXPON.DIST Date Time Of Last Edit: 2023-05-20 22:28:17
