Date/Time: Fri, 13 Nov 2026 22:08:37 +0000
How to adjust space between candles
View Count: 4603
[2019-07-27 13:24:16]
Atlatyl - Posts: 19
Current Version.
How to decrease side by side space between candles while maintaining desired body width? Default Chart Bar Spacing has no effect. I'm after spacing similar to chart on left in pic. Also, is there any way to save as default the price display format? Changing from .00001 to .0001 has driven me nuts for years.
Thanks in advance.
imagecandlespacing.jpg / V - Attached On 2019-07-27 13:22:02 UTC - Size: 42.36 KB - 745 views
[2019-07-27 16:38:57]
There is not a way to do exactly what you want. Here is the relevant documentation for the control of the chart bar widths:
Graphics Settings: Chart Bar Widths
To set a specific Price Display Format that will be used when you create a new chart for a symbol, you would need to adjust the Symbol Settings and change the Price Display Format for that symbol. Refer to the documentation here about how to adjust symbol settings:
Global Symbol Settings: Instructions
Date Time Of Last Edit: 2019-07-28 00:58:51
[2019-07-28 00:58:57]
Prior post has been updated.
[2022-11-03 08:35:23]
User278014 - Posts: 4
Please solve the issue with decreasing the space between bars with keeping the desired bar size
Would be great for me also!
Thank you
Great software and surelly great team at Sierra!
Atached an example bellow of how numbers bars take up too much space for what info i need.
Thank you
imageCapture.PNG / V - Attached On 2022-11-03 08:34:49 UTC - Size: 28.9 KB - 359 views
