Date/Time: Thu, 26 Nov 2026 03:19:23 +0000
Session Highlighting
View Count: 2230
[2019-07-26 20:04:08]
User628616 - Posts: 132
my chart is black and shows regular trading & after hours trading, how do I have the globex session highlighted? like the example photo
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=30274
[2019-07-26 21:36:23]
Refer to the following study:
Time Range Highlight
And also this transparent version of it:
Time Range Highlight - Transparent
[2021-10-30 16:00:43]
RetardedJimSimons - Posts: 102
Hi there,
This is fine but if you have multiple symbols the session hours are different, for example CL vs ES. Is there a way to use a symbol-specific range for the session hour? For example, I already have to configure it in Chart->Settings, doing it twice seems unnecessary. Would be nice if there was a "use session hours from chart settings" toggle on the study settings. For example, volume profile uses the chart settings (or at least appears to).
Thanks.
Date Time Of Last Edit: 2021-10-30 16:01:57
[2021-10-31 16:22:45]
We have set this as a Feature Request.
[2026-03-02 06:20:52]
Sierra_Chart Engineering - Posts: 25489
This will be in the next release:
