Date/Time: Mon, 14 Sep 2026 08:33:57 +0000
Sierra Charts with Interactive Brokers
View Count: 2362
| [2013-04-11 03:20:22] |
1. You can use any Sierra Chart package. 2. Yes. Refer to this page: http://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html You will need to change the symbols of the charts following the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_SwitchingSymbols.html 3. Yes, but you will just have to see and make your own decisions. We will not comment further on this. In general the IB data feed is substandard compared to using TT with Velocity. The difference will probably be so dramatic that you may not want to leave Velocity. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-11 03:20:57
