Date/Time: Tue, 17 Nov 2026 17:16:40 +0000
Two Instances of Large Volume Trade Indicator - Different Settings Issue
View Count: 837
[2019-07-25 01:15:50]
Acro - Posts: 459
If you have two instances of this indicator on a chart with different settings for input 1 then you get an infinite loop - ie the chart will keep reloading itself and never stop until you remove one of the study instances.
The only other explanation I can think of is that I have Combine Trades into Original Summary Trades ticked for that chart.
Is this a known issue with the LVTI study ?
[2019-07-25 06:28:38]
Yes this is true. This behavior does make sense when you have more than one instance of that study on the chart.
