Date/Time: Tue, 17 Nov 2026 17:18:33 +0000
Binary Wave showing 0 value
View Count: 1245
| [2019-07-24 16:14:08] |
| User648008 - Posts: 13 |
I have been using the Moving Average Binary Wave chart, the chart will go to a 0 value and the line will stop until it returns to the 1/-1 value or changes value to 1/-1. This is very different from the previous versions. What changes were made to cause this issue. I have attached a few snapshot so you can see the issue. https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=30232 |
| [2019-07-24 19:04:47] |
| User90125 - Posts: 715 |
Review this thread: Moving Average Binary Wave Study |
| [2019-07-24 20:18:28] |
Zero values are now drawn with this study because sometimes values are zero. Also that screenshot is not clear. It is too small. When posting an image of a chart only use the method here: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
