Date/Time: Tue, 17 Nov 2026 17:18:32 +0000
Need better delta filtering
View Count: 961
| [2019-07-24 04:42:55] |
| daniel1950 - Posts: 13 |
Hi. Does sierra have the ability to filter delta through order size? For example my friend uses Investor/RT and they can filter delta. I have attached an image. I want to be able to see the net delta of trades that have been 100+ lots etc..
| [2019-07-24 04:59:06] |
Yes. Refer to: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) Also refer to: Chart Settings: Combine Trades into Original Summary Trade (Data Feed and Exchange Specific) (Chart >> Chart Settings >> Chart Data >> Chart Data menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-24 04:59:19
