Date/Time: Tue, 17 Nov 2026 17:18:29 +0000
[Programming Help] - Discrepancy: Custom Round Turn Commission only working in charts but not DOMs
View Count: 1567
| [2019-07-22 14:54:37] |
| tesseract353 - Posts: 66 |
In Trading DOMs, when Use Custom Symbol Settings Values is enabled in Global Symbol Settings, Round Turn Commission is not calculated in the DOM's Trade Window or the DOM's DPL. However, Round Turn Commission is working as it should for Trade Windows and DPL that are attached to any Chart. The number of ticks profit and loss between DOM's and Charts is also discrepant even when the Profit/Loss Format is set to the same setting between the two. Date Time Of Last Edit: 2019-07-22 14:56:14
| [2019-07-23 15:37:50] |
| User972768 - Posts: 166 |
I have noticed the same thing after upgrading from 1941 to 1953 - DOM doesn't take into account commissions anymore
| [2019-07-24 09:40:12] |
We examined this and we cannot reproduce the problem but we have determined there was an issue as described here which will be resolved in the next release: Corrected a problem in a chart Trades list where regardless of how Chart >> Chart Settings >> Advanced Settings 3 >> Use Symbol Commission Setting in Trades List and Statistics Calculations was set, the Round Turn Commission was always used in the calculations if it was set on the Symbol in the Global Symbol Settings.
Relevant setting: Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu) The number of ticks profit and loss between DOM's and Charts is also discrepant even when the Profit/Loss Format is set to the same setting between the two. Trade Activity Log: Solving Inaccurate Trade Statistics for Charts Field Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-24 09:42:15
