Date/Time: Tue, 17 Nov 2026 17:16:45 +0000
How I can write/access info from the Dom columns General Purpose 1 & 2
View Count: 3395
| [2019-07-19 23:30:19] |
| User145885 - Posts: 15 |
Hello .Is there anyone kind enough to guide me on how I can write and access info from the Dom columns General Purpose 1 & 2 using acsil Thanks in advance Bill |
| [2019-07-23 02:42:25] |
Refer to the documentation here about this: ACSIL Interface Members - Functions: sc.GetDOMColumnLeftCoordinate() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-07-23 22:57:57] |
Thanks for your response."Refer to the documentation here about this: ACSIL Interface Members - Functions: sc.GetDOMColumnLeftCoordinate()" I know that with those functions you mentioned on your post I can get the coordinates left and right from the DOM, but maybe it was my mistake not to be more specific. I understand that using the following I can use the label column to display/access StackPullValueAtPrice MyGraphBid.DrawStyle = DRAWSTYLE_SUBGRAPH_NAME_AND_VALUE_LABELS_ONLY; MyGraphBid.LineLabel = LL_DISPLAY_VALUE | LL_VALUE_ALIGN_DOM_LABELS_COLUMN | LL_DISPLAY_CUSTOM_VALUE_AT_Y; int StackPullValueBid = sc.GetBidMarketDepthStackPullValueAtPrice(sc.Bid); With the function that you mentioned in your post I know that I can get the X left and right coordinate from different columns from the DOM int GeneralPurposeColumnLeft = sc.GetDOMColumnLeftCoordinate(n_ACSIL::DOM_COLUMN_PRICE); 1)What I dont know is how to get the info from the DOM columns using those coordinates also 2)What I dont know is how to write in the DOM_COLUMN_GENERAL_PURPOSE_1 DOM_COLUMN_GENERAL_PURPOSE_2 columns and then access the info using those coordinates. Is there a function to get those values like we can do it with the dom_labels_column? Can you help me on how to accomplish what I am looking for? Thanks in advance Bill |
| [2019-07-25 08:30:24] |
1. There is not a way to do this. You can only programmatically access the coordinates. 2. You can only draw in them using the Windows GDI which is documented here: ACSIL Programming Concepts: Custom Free Form Drawing into Chart Window And there is not a way to access any values in those columns. They can only be drawn into by using the Windows GDI. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
