Date/Time: Wed, 04 Nov 2026 15:07:07 +0000
vertical lines every 5 min on a one min chart?
View Count: 2765
| [2019-07-19 22:13:42] |
| User66360 - Posts: 81 |
Im looking for a vertical line study that will plot a line every five minutes. On the 5s it will be dashed, 15 min, 30, and 60's thicker to show when a new candle starts on my higher timeframes. Anyone know how to do this? Thanks
| [2019-07-20 05:25:25] |
Refer to: Chart Menu: Vertical Grid (Chart menu) You can use custom grid color and appearance settings per specific chart: Graphics Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-20 05:25:31
| [2019-07-20 14:23:43] |
Would I need to add the study several times for each vertical line? Or could I do multiple lines from the study ?
| [2019-07-22 17:51:36] |
It is not a study. It is an option which draws a vertical grid at the specified interval.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-22 17:51:56
| [2021-02-02 17:52:23] |
| GravisHTG - Posts: 321 |
This is what I was looking for but , When using tick chart, i got extra line in my empty space, Is it possible to remove that ?
