Date/Time: Tue, 17 Nov 2026 17:16:35 +0000
Based on + / -
View Count: 1950
| [2019-07-15 15:15:34] |
| User301279 - Posts: 1 |
Is there a way to designate that you want +/- to be "50" instead of zero? I'm trying to get my RSI to change color above or below the "50". Thank you
| [2019-07-15 15:22:35] |
| Cavalry3162 - Posts: 523 |
fwiw, i second that req.. i had plenty of use cases in the past where i wanted it based on 100 or 50 |
| [2019-07-30 17:54:50] |
| Ackin - Posts: 1866 |
Hi, If you want repaint study with autocoloring function based on +/- dynamic "null" line , you can download study for free from our CZ/SK forum (just Study in dll file, not code). Study: Coloring Based +/- contact link: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free Date Time Of Last Edit: 2020-06-24 22:30:42
| [2019-07-30 18:05:54] |
No, this is not supported. You would need to create your own custom study that does custom coloring: Advanced Custom Study Interface and Language (ACSIL) Or use the Color Bar Based on Alert Condition study: Color Bar Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-30 18:06:26
