Date/Time: Sat, 03 Oct 2026 15:44:49 +0000
How can you change CQG WEB API Data feed password?
View Count: 1784
| [2019-06-27 00:32:16] |
| User719501 - Posts: 9 |
I just had my FCM reset my CQG data feed password. How do I change it to my own?
| [2019-06-27 01:47:58] |
This is controlled through: Global Settings >> Data/Trade Service Settings >> Service Setting >> Password Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
