Date/Time: Sat, 03 Oct 2026 15:44:46 +0000
bar numbering study
View Count: 960
| [2019-06-26 12:26:24] |
| cmb999 - Posts: 211 |
hello, i created a symbol with data : Date, Open, High, Low, Close, Volume
2010/01/04, 100, 100.2, 98.8, 99, 1000 2010/01/05, 99, 99.2, 97.8, 98, 1000 2010/01/06, 98, 98.2, 96.8, 97, 1000 2010/01/07, 97, 97, 95.8, 96, 1000 2010/01/08, 96, 96.2, 94.8, 95, 1000 2010/01/11, 95, 96.4, 94.8, 96, 1000 2010/01/12, 96, 97, 96, 97, 1000 2010/01/13, 97, 98, 97, 98, 1000 2010/01/14, 98, 99, 98, 99, 1000 2010/01/15, 99, 100, 99, 100, 1000 2010/01/18, 100, 101, 100, 101, 1000 2010/01/19, 101, 102, 101, 102, 1000 2010/01/20, 102, 103, 102, 102, 1000 2010/01/21, 102, 102, 101, 101, 1000 2010/01/22, 101, 101, 100, 100, 1000 2010/01/25, 100, 100, 99, 100, 1000 2010/01/26, 100, 101, 100, 101, 1000 2010/01/27, 101, 102.5, 101, 102, 1000 2010/01/28, 102, 102, 101, 101, 1000 2010/01/29, 101, 101, 100, 100, 1000 2010/02/01, 100, 100, 98, 99, 1000 2010/02/02, 99, 99, 97, 99, 1000 2010/02/03, 99, 100, 99, 99, 1000 2010/02/04, 99, 100, 99, 99, 1000 2010/02/05, 99, 99, 99, 99, 1000 i applied the Bar Numbering study. Every bar is labeled 1 Also, is it possible to start at 0. isn't that the case with ACSIL ? |
| [2019-06-26 15:06:54] |
| John - SC Support - Posts: 48095 |
Make sure you have the option for Do Not Reset at Start of New Day set to Yes. Refer to the documentation here for this setting: Bar Numbering There is no built in way to start the count at 0. You could modify the study yourself to do this. It is located in the Studies2.cpp file found in the ACS_Source folder under your Sierra Chart installation. Refer to the documentation here for how to build a study from source code: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-06-26 15:16:27] |
That study has an Input to control whether it resets every day. Make sure it is set to not reset every day.
