Date/Time: Sat, 03 Oct 2026 15:44:27 +0000
back-adjustment not being applied only to most recent rollover
View Count: 857
| [2019-06-26 07:36:47] |
| User753428 - Posts: 185 |
I have enabled Continuous Contract: Volume-Based Rollover, Back Adjusted; but the problem occurs for Date-based Rollover, Back Adjusted too. Now the issue: When I have loaded an INTRADAY chart, I see that the back-adjustment is not applied to the most recent rollover; BUT back-adjustment is applied to all rollovers that occurred prior to the most recent rollover. When I have loaded a HISTORICAL chart, the back-adjustment is applied to every rollover as intended, so no problems here. I experience this problem on every single symbol and Delete Data & Redownload hasn't fixed the issue for me either so I don't think it's a problem of having missing historical data for a particular symbol. Oddly enough, I only experience this problem with CQG. When using Rithmic, I do not have this problem. Date Time Of Last Edit: 2019-06-26 07:47:25
| [2019-06-26 20:23:18] |
For what symbol? Just tell us one of the symbols.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-26 20:23:59
