Date/Time: Sat, 03 Oct 2026 15:45:27 +0000
Cumulative Delta-Volume bars w/ Daily RTH...
View Count: 1610
| [2019-06-25 23:58:17] |
| User629089 - Posts: 93 |
Hi, I don't understand why a Cumulative Delta Bar-Volume study seems to be fixed to a "0" level as opposed to "free floating" and cumulative for an RTH session (8:30:00 - 15:14:59) daily bar. All study parameters are exactly the same as the 1 Min and 2 Tick Renko charts that I use this study with. Attached is that daily chart I'm referring to. I've never been able to figure this out, even thinking it might have something to do with the Chart Settings but no luck there either. Any ideas? Thanks... http://www.sierrachart.com/image.php?Image=1561506535466.png |
| [2019-06-26 03:32:59] |
It is set to reset every day. So what you see does make sense.
