Date/Time: Sat, 03 Oct 2026 15:45:15 +0000
Total (t)icks in Trade Activity Log
View Count: 1061
| [2019-06-25 16:56:13] |
| seandunaway - Posts: 398 |
Is the Total little t ticks in the Trade Activity Log calculated incorrectly? Shouldn't the Total (t)icks in attached image be 13t? |
| [2019-06-25 18:18:16] |
Refer to the documentation here for the calculation method: Trade Activity Log: Trades Fields Descriptions refer to the description for Total Profit/Loss. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-06-25 18:22:29] |
Does an average make more sense than a total here? I guess it's handy either way. Thank you! |
| [2019-06-25 18:42:58] |
Do you mean rather than summing the ticks when using the Ignore Quantity format, to perform an average instead? Yes that may make sense.
| [2019-06-25 18:58:28] |
To me total makes more sense than average. Right now each line item is totaled but the Total at the bottom is averaged, which does seem a little inconsistent. (I love your software) |
| [2019-06-26 15:31:46] |
Also, is there a technical reason why the Trade Activity Log is unable to show T or t ticks in the Profit / Loss column when All Symbols are selected?
