Date/Time: Sat, 27 Apr 2024 15:39:07 +0000
[User Discussion] - Spreadsheet
View Count: 2242
[2019-08-02 20:27:19] |
AndreyPoroshin - Posts: 102 |
the link does not work
[2019-08-02 23:44:50] |
Sawtooth - Posts: 3978 |
You want to say that it is possible to implement this in ACSIL?
Even if it is possible with ACSIL, your intrabar concept will likely become more complex/complicated than you realize.What will the formula look like, determining that within one minute the price movement has passed 5 points? Timeframe 1 second.
You could do a rolling 1 sec HL range with a 60 sec lookback with a formula like this:=MAX(C3:C62)-MIN(D3:D62) Date Time Of Last Edit: 2019-08-03 01:40:06
[2019-08-06 14:54:33] |
You can contact me here:https://www.sawtoothtrade.com/contact.html |
[2019-09-25 18:36:29] |
Hello, I tried to find a solution, but did not find it. If you tell me, I will be very grateful. When a buy order is executed, I need to determine the Low of the bar on which the transaction took place. It is easy- = IF (K3> 0, D3, AC4). The price level that is calculated by this formula is needed for me to set a limit stop order The question is what is used in the formula (K3> 0) and, accordingly, if another trigger to buy occurs on the next bar, the formula works again and the stop price level changes to a new level corresponding to the last price. I would rather stay at the old level from which my trade lasts. How can I do this? I also tried the options, = IF (FRACTIME (A3) = (FRACTIME (J42), D3, AC4) but this does not work. Maybe there is a calculation formula for Last Entry Fill Price, based on which it will be possible to find other prices in the Fill Price area? |
[2019-09-25 22:13:13] |
In another Formula Column, create a persistent variable of the Buy Entry, then find the transitions in K3: P3: =IF(YourBuyEntryConditions,1,IF(YourSellEntryConditions,0,P4)) K3: =AND(P4=0,P3) This is the basic concept. You might need to modify for your needs. There are examples of this here: Spreadsheet Example Formulas and Usage |
[2019-09-26 13:28:29] |
I managed to enter your site through a proxy. A lot of interesting, thanks. I will contact
[2019-09-26 13:36:47] |
While I was waiting for the answer to my question, I temporarily did this: AC =IF(AND(FRACTIME($J$42)>FRACTIME(A3),K3>0),D3,0) AE =IF(AND(FRACTIME($J$42)>FRACTIME(A3),M3>0),C3,0) this formula eliminates zeros =MOSTRECENTNONZEROVALUE(AC@3:AC@100) =MOSTRECENTNONZEROVALUE(AE@3:AE@100) |
[2019-09-26 14:49:21] |
=SUM(INDEX(F$3:F$1002,MATCH($H$3,Z$3:Z$1002,-1),1) :INDEX(F$3:F$1002,MATCH($H$4,Z$3:Z$1002,-1),1)) The formula for calculating the volume from your site. It is not clear what she is showing. First in cell H6 #REF? Secondly, if I disassemble it into components in columns V X, the result AA is not corresponding to the sum of the volume in the interval between 08:25:00 - 14:40:00. Maybe I did not understand the functionality correctly? Date Time Of Last Edit: 2019-09-26 14:51:20
Private File |
[2019-09-26 16:30:11] |
Use this formula instead: =SUM(INDEX(F$3:F$1002,MATCH($H$4,Z$3:Z$1002,-1),1):INDEX(F$3:F$1002,MATCH($H$3,Z$3:Z$1002,-1),1)) Note: H3 must be earlier than H4. The original formula does not work in the New Spreadsheets. The webpage has been updated. |
[2019-11-21 17:03:23] |
Hello, which of the formula operators can be used to solve my problem? X- for example, the average delta curve = MAX (X3: X7) I calculate the maximum delta value for the period from 3 to 7 I need the value 7 in (X7) to be dynamic, and to be substituted from another cell, for example (Y3) - that is, I always know this value. It is calculated in column (Y) As a result, I want to apply this dynamic value, but I don’t know with which operator this can be done correctly? = MAX (X3: X7) = MAX (X3: X (Y3)) simply put, instead of seven you need a value from column Y Date Time Of Last Edit: 2019-11-21 17:05:48
[2019-11-21 23:13:16] |
If you don't want to include X7: =MAX(X3:X6,$Y$3) Or if you do want to include X7: =MAX(X3:X7,$Y$3) |
