Date/Time: Wed, 18 Nov 2026 09:00:53 +0000
Swing high low pivot line
View Count: 7053
[2019-06-12 15:49:04]
User276793 - Posts: 58
Hi i am looking for an indicator that can draw a horisontal line across the last swing high and swing low. If possible can set how many candles it counts before meashuring a new high or low as well. I did find one called Market Structure MSL/MSH but can't figure out how to get the horizontal lines to draw off the last pivot high and low.
In the image i attached it does have the lines so i guess it is possible just have not figured it out.Mayby just a setting adjustment?
thanks
Private File
[2019-06-12 18:43:15]
If you use the Swing High and Low study it does support adding extension lines until future intersection:
Swing High and Low
This may not be exactly what you want but that's the closest we have. Also, the study can be modified to meet your requirements.
[2019-06-12 21:47:03]
Ackin - Posts: 1866
It's possible download it for free from our CZ/SK forum.
Study: Swing high low pivot line
contact link:
Date Time Of Last Edit: 2020-06-24 22:15:43
[2019-06-14 00:02:13]
Ackin - Posts: 1866
Improved:
1) Use one or two swing back
2) changeable display type:
a) Line
b) Zone by wicks
c) User ticks range
Date Time Of Last Edit: 2020-06-24 22:16:29
[2019-06-14 23:40:26]
Yes the image you attached is what i am looking for but the indicator Swing High Swing Low on my chart only has arrows no lines off the last pivot high and pivot low.
imagesierra charts swing high low.PNG / V - Attached On 2019-06-14 23:40:20 UTC - Size: 58.22 KB - 1885 views
[2019-06-15 09:10:31]
Ackin - Posts: 1866
you asked for a study that is default in Sierrachart (was answered in #2 by admin)
I made improvements to this study - visualizing the last swing(variable parameter only last or .... last and last-1 swing) from all the marked swings
For clarification I sent a "screenshot of completed study" #4 not my drawing. You can download it for free on our forum (+ more than 100 other free studies), the link is above.
Adjustments are possible, just try it and write the idea of what to change.
Currently: added the possibility of alert conditions last swing as subgraph (reference last swing for user alerts formulas), the study will be improved with others possibilities in the future.
Date Time Of Last Edit: 2019-06-15 09:20:34
[2020-06-03 19:11:40]
User434251 - Posts: 15
I just realized I neglected to thank you.
Thanks!
