Date/Time: Thu, 05 Nov 2026 11:45:02 +0000
data trade service down
View Count: 966
[2019-06-07 16:28:09]
User968951 - Posts: 3
hello, since this morning my data service don't work (fxcm demo)
and other service don't work too.
problem with the system on your side ?
[2019-06-07 16:28:25]
Provide a copy of the Message Log by following these instructions:
Sierra Chart Support
[2019-06-07 17:17:13]
tried to uninstal, and reinstal the software, the installer don't want download the file, my firewall is desactivated
[2019-06-07 18:22:35]
This is what we want you to do. We want you to run Sierra Chart if it is not running or restart if it is running and enable the Force Login option on the login window. Let us know if you can then log into Sierra Chart.
[2019-06-07 18:36:47]
thanks, problem solved, it was my internet type connection (wifi) changed with cable, now it's working.
