Date/Time: Thu, 05 Nov 2026 11:44:53 +0000
How would I be able to list the top 50 weightings' NQ constituent stocks into a chart?
View Count: 1013
| [2019-06-07 13:29:08] |
| User14410 - Posts: 38 |
How would I be able to list the top 50 weightings' NQ constituent stocks into a chart and represent each of them using different degrees of green and red color based on the % of their increase in price within that particular day individually?
| [2019-06-07 14:58:01] |
You would first want to use this study: Add Additional Symbol And have a look at these additional studies to help with what you need to do: Percent Change Since Open Color Background Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-07 14:58:51
| [2019-06-07 15:03:26] |
Thank you. But it seems that the links above might not be aiming at creating something like in my attached photo... Do I misunderstand you?
| [2019-06-08 02:23:29] |
The closest available like this would be the Quote Board. Refer to the documentation here: Getting Quotes: Quote Board Also have a look at the Study Summary window: Study Summary Window Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
