Date/Time: Thu, 05 Nov 2026 11:44:52 +0000
Study search
View Count: 991
| [2019-06-07 13:13:26] |
| User875891 - Posts: 63 |
Is there an Study similar to Average price for bar but instead shows the highest vol at price on that bar?
| [2019-06-07 14:45:49] |
For this you would probably want to use the Volume by Price study where each profile is set to 1 Bar. Volume By Price Study And set it to highlight the point of control. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
