Date/Time: Thu, 05 Nov 2026 11:45:06 +0000
Market Depth ghosting
View Count: 924
| [2019-06-07 08:41:50] |
| User132748 - Posts: 159 |
Despite setting 'Extend last known depth" to NO, Market Depth Historical is ghosting previous depth info in ranges where SC was closed and wasnt receiving any depth info from datafeed. I expect it should be totally off and show clear background not those smudges so I could clearly see wheres no depth info. Could you fix it? Thanks
Date Time Of Last Edit: 2019-06-07 08:42:18
| [2019-06-07 14:40:56] |
We may have to make sure that when disconnecting from the data feed all market depth levels are deleted. We will look into that.
