Date/Time: Thu, 05 Nov 2026 11:44:56 +0000
Update chart doesn t seem to work
View Count: 948
[2019-06-06 18:28:11]
User162290 - Posts: 11
as you can see on the image ... the Micro ES is missing a lot of data versus the MINI ES. it is normally 99 % tick for tick. I think there is an issue with my data download update on my chart . I tried to download it a few times..even close Sierra and opened new chart and chart book but there is still a big chuck of data missing ?
what can i do to get it back ?
thanks Kevin
imageerror data missing es versus micro es.png / V - Attached On 2019-06-06 18:25:16 UTC - Size: 103.49 KB - 365 views
[2019-06-06 21:01:19]
Follow the procedure here to download that missing data:
If it is still missing, let us know.
[2019-06-07 18:14:41]
great it worked by doing this :
Right-click your Pointer and select Delete and Download Data on the Chart Shortcut Menu. This will delete and re-download from the position you pointed to, all the way to the end of the data file. You will see Downloading Historical Data displayed on the chart window. Refer to the image to the right.
cheers
