Date/Time: Tue, 24 Nov 2026 09:33:35 +0000
v1928 doesn't support multiple profiles for vbp
View Count: 1211
[2019-06-06 11:03:18]
styloZ - Posts: 5
Hey Support Team,
ever since I updated Sierra Chart to v1928 at the start of the week, I can't see multi volume profiles for the VBP study, based on cash and after hours session.
I've double checked my study settings to ensure I've got everything in the right order, but nothing seems to fix the issue.
Any assistance would be great appreciated.
Cheers
[2019-06-06 19:48:34]
We would need to get that chart to have a look at it. Follow the instructions here:
[2019-06-06 19:58:52]
styloZ - Posts: 5
Here is the chart example. Thanks again for the help.
attachmentES Test.Cht - Attached On 2019-06-06 19:58:25 UTC - Size: 204.81 KB - 595 views
[2019-06-06 22:16:46]
John - SC Support - Posts: 48633
This has nothing to do with the version. You just need to change your setting for Volume Graph Period Type to Multiple Profiles Based on Fixed Time.
Evening sessions are not supported with the other settings. This is described in this part of the documentation:
Volume By Price Study: Use Separate Profile for Evening Session
[2019-06-07 03:47:01]
styloZ - Posts: 5
Thanks for the tip as its worked now.
It definitely worked before when I had it set to Multiple Profiles from start to end time, but I'm glad its all sorted.
This thread can be closed now.
