Date/Time: Wed, 11 Nov 2026 11:44:49 +0000
I would like to receive quotes from the NYSE
View Count: 1053
| [2019-05-29 16:23:12] |
| AndreyPoroshin - Posts: 105 |
Hello, I have one question. I would like to receive quotes from the NYSE, in particular, some ETFs such as SPY and QQQ. What should I connect. Not for trade, but for research. I am licensed to the platform through an AMP broker
| [2019-05-29 18:47:47] |
Real-time data or just historical data?
| [2019-05-29 19:49:07] |
Tick by tick. Real only
| [2019-05-29 19:51:16] |
do historical data have a time delay?
| [2019-05-30 04:56:17] |
If you require real-time data you will need to use the Sierra Chart Exchange Data Feed. Set up instructions on this page: Sierra Chart Exchange Data Feed Historical data will have a delay of 15 minutes . In this particular case you will want to use your own direct Sierra Chart account and then you will have access to the Sierra Chart historical data service and do not need to use the Sierra Chart Exchange Data Feed in this case. Refer to: Direct Sierra Chart Account Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-05-30 19:00:11] |
| User367914 - Posts: 2 |
I have read the terms. Some details are not clear, ie the depth of the market is not available for Nyse shares, what does this mean? I plan to follow the SPY and QQQ tools, does this mean that they will not have time and sales and DOM? If so, then tell me which exchange I can connect to see the information I need. Maybe CBOE?
