Date/Time: Sat, 17 Oct 2026 13:03:35 +0000
Volume Profile Not Developing on Chart
View Count: 878
| [2019-05-29 02:49:04] |
| User997723 - Posts: 2 |
Hello- I have two charts; Both have Volume Profile's and set up exactly the same in the VbP settings including the Settings and Input, Subgraphs tab. Chart settings are set up exactly the same including time periods. One of the charts show a VP developing in the evenings and the other chart does not. I am out of answers. Can you please help? I attached three pictures of the chart; one with the evening VP, the other doesn't have it and the last is the settings. Thank you.
| [2019-05-29 05:02:03] |
Refer to: Volume By Price Study: Volume Profile Differences If you want the charts to be exactly the same duplicate one of them with Chart >> Duplicate Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-29 05:02:48
| [2019-05-29 05:06:34] |
| DG_Tradez - Posts: 82 |
Yes I did duplicate them.
| [2019-05-29 10:40:13] |
If the charts are an exact duplicate of each other,assuming you did not make any changes to either of them, then they definitely will match when you select Chart >> Reload and Recalculate for each of them. Do that. The documentation we linked to does describe this.
